Lildudes Ultimate 931 EFR Build
Goto page Previous  1, 2
lildude4life
PostPosted: Mon Sep 24, 2018 12:08 am    Post subject: Reply with quote
She now has EFI! Full post coming soon. I want to work all the kinks out before I post anything.
What would you like to know?
"931 EFR" 81 931 S2 w/ EFR 6258 turbo, EFI, Haltech Elite ECU, 240whp
WEASEL149
PostPosted: Mon Sep 24, 2018 1:38 am    Post subject: Reply with quote
We want to know EVERYTHING
Very nice build. Well done man
1979 UK 932
PostPosted: Mon Sep 24, 2018 1:44 am    Post subject: Reply with quote
+1, everything would be nice
PostPosted: Mon Sep 24, 2018 2:20 am    Post subject: Reply with quote
You're all going to love it. Definitely need to suscribe for the updates. Lildude has kept excellent documentation on this build. It's well executed and the car is 99% there, just a few wrinkles to iron out with the EFI programming.
lildude4life
PostPosted: Mon Sep 24, 2018 7:25 am    Post subject: Reply with quote
Didn't your mother ever teach you, when you ask for everything, you get nothing?
Ask me some questions, and I will be happy to answer.
Main issue I'm having before I do a similar EFI post is that "I think" (raceboy may disagree) I'm having computer related fuel cut issues. Once that is sorted out, and I get a few hundred more miles on it before it snows, then I'll do a full recap of the EFI. Sad to say though, Dan and I were working on it together to put the Ideola EFI kit together, and that may no longer be a thing. But if I can at least document everything I did, and what Raceboy provided, it may help quite a few other 924er's do a conversion.
WEASEL149
PostPosted: Tue Sep 25, 2018 5:58 am    Post subject: Reply with quote
So now you've mentioned the magic name 'Raceboy', I take it this is a VEMS based conversion?
I have all the VEMS gear ready from Raceboy but just haven't had mental capacity to finish the final leg on my own project due to a multitude of bad shit happening over the last 2 years. It will be continued very shortly though with any luck.
So , questions. Which injectors? Batch or sequential? I guess you went with front pulley mounted crank trigger (36-1)?
Fully documented how-to sounds cool - I do intend to do similar when mine finally gets finished.
1979 UK 932
lildude4life
PostPosted: Tue Sep 25, 2018 7:26 am    Post subject: Reply with quote
Yes VEMS via Raceboy
Injectors: Siemens 60lb model: 107961
Batch. Doing Sequential would require a secondary trigger wheel on the camshaft, and I wanted to keep it as KISS as possible.
Correct.
PostPosted: Wed Sep 26, 2018 11:25 pm    Post subject: Reply with quote
A 'lil teaser
https://vimeo.com/291914979
Taken at the last 4th Friday
poor-sche
PostPosted: Thu Sep 27, 2018 6:10 am    Post subject: Reply with quote
Looking forward to reading the write up on this, but was wondering if it's worth while doing this upgrade if your CIS is operating normally?
Would this upgrade be strictly for more FUN factor or is it also for reliability?
Looking for justification points for the boss.
PostPosted: Fri Sep 28, 2018 12:03 am    Post subject: Reply with quote
in lil'dudes case its a 'tad' different. He is running a Borg Warner EFI Turbo. Look closely at the Avatar
Of course, set up correctly you'll get reliability and with that fun. If your set up is stock and the CIS is running fine, I wouldn't bother.
Page 2 of 2
