Joined: 08 Jun 2010 Posts: 740 Location: Maysville, Colorado
Posted: Mon Sep 17, 2018 6:07 am Post subject: MSDS header Problem |
I havet a, used, never installed MSDS(I think) header and an installation problem. On cylinder #4 between the tight curve of the pipe and the cast iron fin of the motor mount there isn't enough room to get a wrench in to tighten the bottom exhaust flange bolt. It appears that the best way to resolve it is to take off the motor mount and remove a bit of the cast iron fin.
Any comments on this?? _________________ Mike
'77 924
cricketdesigns.com |
Joined: 28 Feb 2008 Posts: 1019 Location: Washington DC area
Posted: Mon Sep 17, 2018 6:29 am Post subject: |
Yes, that's what I did. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Posted: Mon Sep 17, 2018 6:48 am Post subject: |
Thanks for the quick reply, I've taken the header off and am about to go out after the motor hoist. Two steps forward-one step back. _________________ Mike
'77 924
Posted: Fri Sep 28, 2018 1:04 am Post subject: |
Can you guys post a pic of this? _________________ 1980 931 ...off with the cobwebs
0.5 1982 931 smashed parts car
1982 931 parts car?
Posted: Sat Sep 29, 2018 12:03 pm Post subject: |
I can't as is now buried under the header. Basically there is a vertical rib on the firewall side of the top of the cast iron motor mount that interferes with the bottom nut for th cylinder #4 flange. I used a hacksaw to cut off the rib to just below the center of the bolt hole where it bolts to the block. The cast iron is easy to cut with a hack saw.
There is also a bolt flange close to the center of the curved cast iron arm. It is pointed forward. It needs to be sawn off due to pipe interference.
There is a second bolt flange down toward the bottom, it does not need to be removed(for MSDS), I tried to bend up a heat shield to fasten there, but after about 4 hours of tinkering I had to abandon it as the 8mm bolt only can go in from the bottom and I couldn't get a bolt started due to the congestion of pipes. _________________ Mike
'77 924
Joined: 29 Jul 2001 Posts: 8128 Location: Royal Oak, MI, USA
Posted: Sat Sep 29, 2018 11:05 pm Post subject: |
Yeah I too have a heat shield there, was able to get a bolt in that flange but no it wasn't easy.
I changed over to an allen head screw for the last lower bolt on the header. Still not super-easy to use, but worked better than a nut and stud... _________________ Vaughan Scott
'79 924 #77 ITB racecar
Noahs944
Joined: 08 Dec 2015 Posts: 732 Location: Calgary, Alberta, Canada
Posted: Tue Oct 09, 2018 1:19 am Post subject: |
Sometime with headers it's best to gradually tighten the fastener while slight pressure is pulling the header away from the head (rather than snug it up with the fasteners that are easy to access first).
I remember struggling with my header. |
Noahs944
Posted: Tue Oct 09, 2018 1:20 am Post subject: |
