vwfye
Posted: Wed Sep 12, 2018 2:15 pm Post subject: Which is faster? |
Dropping torque converter/trans or pulling the engine? |
Russmw
Posted: Wed Sep 12, 2018 6:00 pm Post subject: |
Can I presume this is to do the clutch?
I've just finished this job and did it by removing the gearbox (5 speed), slide the torque tube back then remove the bell housing. In my opinion if you have an engine lift I suspect lifting the engine maybe easier\faster as access woudl be far better but then I did the job lying under the car and maybe with a 4 pillar lift would have a different opinion? _________________ 1982 924 2.0 Lux
(Alpine White) |
vwfye
Posted: Wed Sep 12, 2018 11:56 pm Post subject: |
Yep, my throwout bearing is very noisy right now. |
vwfye
Posted: Wed Sep 12, 2018 11:58 pm Post subject: |
My options are lying under the car under 4 jack stands or lifting out the engine. |
Posted: Thu Sep 13, 2018 1:41 am Post subject: |
Unless you have another reason to pull the engine, just slide the torque tube/tranny back and remove the bell housing. Haynes has an OK write up. _________________ White 87 924S "Ghost"
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Thu Sep 13, 2018 6:18 am Post subject: |
getting the engine out means removing the Rad
Just having done the engine removal procedure, I believe removing the tranny might be easier _________________ 1979 924 NA |
vwfye
Posted: Thu Sep 13, 2018 6:25 am Post subject: |
Paul wrote: | Unless you have another reason to pull the engine, just slide the torque tube/tranny back and remove the bell housing. Haynes has an OK write up. |
How much of a pain is pulling the shifter to slide it back? |
Kenodog
Posted: Thu Sep 13, 2018 8:03 am Post subject: |
What series is your car ? 1 or 2 ...?
Me _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
vwfye
Posted: Thu Sep 13, 2018 8:06 am Post subject: |
Huh? 1980 2.0 n/a |
Russmw
Posted: Thu Sep 13, 2018 6:42 pm Post subject: |
Mine was rattling\knocking when not in gear & at biting point which all sounded like it was coming from the back of the car. When I removed the inspection cover by the gearbox and grabbed the torque tube coupler I could rotate it by 100+ degrees.
After pulling the clutch it was clear the centre springs were really weak and the tabs in the middle off the clutch were banging against each outher - the release bearing was filthy but fine.
It was however the original clutch with a manufacturing date of July 1981 and the wear was quite low so backs up the 78k on the car.
I did the job with the car on axle stands\jacks and it was ok. More a write up here: https://www.porscheclubgb.com/forum/tm.aspx?m=1006375
Thanks _________________ 1982 924 2.0 Lux
(Alpine White) |
vwfye
Posted: Fri Sep 14, 2018 12:03 am Post subject: |
Bookmarked your write up. Thanks for sharing! |
