rod30
Joined: 05 Aug 2018 Posts: 20 Location: Carrolltom Mo
Posted: Thu Aug 23, 2018 2:43 am Post subject: Testing TPS on 924S |
This is on my 1987 924S.
Reading about testing the TPS says at terminal 2 on the DME connector I should get 0 ohms to ground when closed and infinite ohms with the the TPS open. I do get 0 when closed but I don't know how to read infinite on my meter. |
rod30
Posted: Thu Aug 23, 2018 8:13 am Post subject: Testing TPS on 924S |
OK, I removed the TPS and opened it up and it's broken. The arm that opens and closes the contacts is broken. So, I will by a replacement. |
