WTB: K26 Turbine housing or S2 Turbo Core
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale
Moparboy72
PostPosted: Tue Aug 21, 2018 12:06 pm    Post subject: WTB: K26 Turbine housing or S2 Turbo Core Reply with quote
I am looking for a rebuildable K26 tubine housing for a 924 Turbo, I will also consider an whole S2 turbo for a core to rebuild as long as the turbine housing is not damaged.
Please post or PM; with a photo and a price.
Thanks,
Andrew
Sad turbine housing below:
Kenodog
PostPosted: Thu Aug 23, 2018 11:00 am    Post subject: Reply with quote
ALL turbine housings are cracked. Happens about 5 minutes after the car drives off the dealer's lot. I have a tub of 15 turbos and each and every one is cracked to some degree. Makes zero difference to the way it spools, they spin so fast. If it is important to you then just have someone weld / peen the cast iron.
Me
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kid's limo)
2008 GS500
1996 Dodge Caravan (DJV)
Moparboy72
PostPosted: Thu Aug 23, 2018 11:31 am    Post subject: Reply with quote
Kenodog,
Thanks for the response, I had a similar note on this from CarreraRSR in another thread. I will heed the wise advice and do some minor clean up work then use this housing as is.
I had sent you a PM on one of the manuals you had a thread on.
Thanks again,
Andrew
PostPosted: Thu Aug 23, 2018 6:26 pm    Post subject: Reply with quote
Don't weld it, it will crack in some other place. Let it be and enjoy it.
red 924 and not red 924
Kenodog
PostPosted: Fri Aug 24, 2018 11:43 am    Post subject: Reply with quote
Welding is 100% fine. They housings crack because of two things. The sectional thickness is too great and this causes the housing to crack at the 90 corner. (Otherwise known as a stress riser.) If you have it welded / peened then use a Dremel to radius the corners you will last a s**t load longer than the factory new part.
The above reason are why every single housing cracks in EXACTLY the same spot...
Leg
1981 931, Sabine
2008 GS500
PostPosted: Fri Aug 24, 2018 8:34 pm    Post subject: Reply with quote
IF you do a proper job
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale All times are GMT + 11 Hours
