MikesCoupeGT
Joined: 18 Oct 2006 Posts: 470 Location: Ontario Canada
Posted: Sat Aug 04, 2018 12:08 am Post subject: |
I am going to the track tonight for an open lapping session 2 hours of fun and driving. Cannot wait to get there. It makes the work day go slowly when you are anticipating the fun.
Other than that I need to get under the dash again and look at the dial lights. When the car is on the speedo lights are on, and when I turn the lights on the speedo lights go out!. I think a wire dropped out while I was attempting to get them all to have some night time illumination.
Video (Hopefully) to come later. _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line |
Ian89C4
Posted: Mon Aug 06, 2018 11:25 am Post subject: |
Just a testing day with the widened car...
_________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Kenodog
Posted: Mon Aug 06, 2018 1:59 pm Post subject: |
Ian that is awesome ! Car looks fantastic man, I am very jealous.. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Joined: 10 Dec 2006 Posts: 947 Location: Noosa Heads QLD Australia
Posted: Mon Aug 06, 2018 7:48 pm Post subject: |
+ 1 _________________ 80/81 932/8 ROW |
MikesCoupeGT
Ian89C4
Posted: Wed Aug 08, 2018 11:45 am Post subject: |
Looking good Mike! Great to see another 924 carving it up _________________ Ian Edgerly
North Carolina
Current:
Eric P
Posted: Thu Aug 09, 2018 12:47 am Post subject: |
I decided to upgrade to LED projector headlights last night. Second only to the headlight relay harness, this is one of the best upgrades per dollar I've done hands down. I'll update with pictures of the beam pattern when I find a spot where I can safely stop in a dark area. Even properly adjusted, they cast the light way further than the stock sealed beams or even the E code halogens I was running before.
Some people may not like the blacked out headlight look, but I think it looks way cleaner than the old silver lenses... not that I normally drive around with my headlights up and off at the same time. _________________ 1980 924 NA, US model
1987 924S, US model |
Posted: Thu Aug 09, 2018 6:42 am Post subject: |
Kenodog wrote: | Ian that is awesome ! Car looks fantastic man, I am very jealous.. |
+1 _________________ https://www.the924.com |
Lau Christophersen
Joined: 17 May 2013 Posts: 108 Location: Denmark/Copenhagen
Posted: Thu Aug 09, 2018 10:42 am Post subject: |
Nice!
How.do you mount them? Self made brackets? Any pictures?
I got a pair of 7" led but I have to find a solution to mount them.
Eric P wrote: |
Some people may not like the blacked out headlight look, but I think it looks way cleaner than the old silver lenses... not that I normally drive around with my headlights up and off at the same time. |
_________________ 76 924 (PARTS)
77 924 (PARTS)
77 924 converted to 924S
77 928
79 931
79 931(PARTS).
79 931 Carrera GT look (PARTS).
79 931 with VEMS and opgrades
81 928S +30 cm widebody kit
82 924 (SOLD)
83 928S
86 944
86 944 (S2(SOLD))
89 944 S2 (SOLD) |
Eric P
Posted: Thu Aug 09, 2018 10:26 pm Post subject: |
The ones I bought were just plug and play. They're a sealed unit that replaces the original H6204 sealed beam lens. They fit right into the original headlight bracket and plug right in to the stock harness. I didn't have to make anything at all. Total install for both sides and adjustment was a 15 min affair.
Just a side note: If you do go LEDs, don't just buy LED bulbs. Buy the new lens with the projector and the LED as a sealed unit. They're rated at 50,000 hours so you generally won't have to replace them for the life of the car. To put that in perspective, halogen bulbs typically last about 1,000 hours. It's a lot easier to justify $70+ on headlights when you realize you won't be buying $25 bulbs every few years. You definitely want projector lenses though. Retrofitting a standard halogen lens with LEDs will scatter light everywhere and will blind oncoming drivers. With the sealed projector unit, it's literally plug and play. _________________ 1980 924 NA, US model
Lau Christophersen
Posted: Fri Aug 10, 2018 7:43 am Post subject: |
Eric P wrote: | The ones I bought were just plug and play. They're a sealed unit that replaces the original H6204 sealed beam lens. They fit right into the original headlight bracket and plug right in to the stock harness. I didn't have to make anything at all. Total install for both sides and adjustment was a 15 min affair.
Just a side note: If you do go LEDs, don't just buy LED bulbs. Buy the new lens with the projector and the LED as a sealed unit. They're rated at 50,000 hours so you generally won't have to replace them for the life of the car. To put that in perspective, halogen bulbs typically last about 1,000 hours. It's a lot easier to justify $70+ on headlights when you realize you won't be buying $25 bulbs every few years. You definitely want projector lenses though. Retrofitting a standard halogen lens with LEDs will scatter light everywhere and will blind oncoming drivers. With the sealed projector unit, it's literally plug and play. |
I think my LED's are the same as yours(looks like it from the picture of your car) but there is nothing on the backside for mounting so the front and the LED itself look totally the same but maybe the housing is different than yours…. _________________ 76 924 (PARTS)
77 924 (PARTS)
77 928
79 931
79 931(PARTS).
82 924 (SOLD)
83 928S
86 944
86 944 (S2(SOLD))
89 944 S2 (SOLD) |
Posted: Tue Aug 14, 2018 12:42 am Post subject: |
82' 931
Trans out for seal refresh
Tank out for leaky upper hose fix
Wastegate out for boost controller install
Exhaust updates?...maybe, if time permits
...and 931 billet Alu breather elbow/90deg hose eliminator install. I'll post pics later _________________ 1980 931 since 1989
Posted: Tue Aug 14, 2018 5:25 am Post subject: |
Eric where did you buy your headlights? _________________ White 87 924S "Ghost"
Kenodog
Posted: Thu Aug 23, 2018 12:16 pm Post subject: |
So I found an excellent upholster to install the seat covers onto Olive. Very happy with that and cannot wait to see the finished project. I will be taking them in next Tuesday, they will be done mid-October I'm told.
mE _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
