porsche n/a 924 transmission swap
zubair
PostPosted: Sat Aug 04, 2018 6:11 am    Post subject: porsche n/a 924 transmission swap Reply with quote
hi guys i have porsche 924 n/a 1981 and am swapping in an audi/vw 1.8T because my motor was blown when i baught the car and parts are expensive and difficult to get in South Africa. i wanted to know if there are any bolt in transaxle upgrades i can make. if i get a 944 transaxle what will all need to be changed and is the any bolt on option looking for about 300hp max
zubair solomon
PostPosted: Sat Aug 04, 2018 10:42 pm    Post subject: Reply with quote
944 has a larger input shaft so get the torque tube also. The shift linkage should be the same, but if it's available you might get it also. Someone else will have to comment about the clutch disc. Check the engine swap section there have been several.
Mike
'67 MG Midget Dp
PostPosted: Sun Aug 05, 2018 10:03 am    Post subject: Reply with quote
A Bronco II clutch disc will work...has right spline arrangement for the larger 944 driveshaft.
zubair
PostPosted: Mon Aug 06, 2018 4:00 am    Post subject: Reply with quote
at the moment i have the standard transaxel in but i just wanted to know if there is anything i can directly swap that is stronger
zubair solomon
PostPosted: Mon Aug 06, 2018 6:23 am    Post subject: Reply with quote
Required reading.
http://garage.ideola.com/downloads/G31-Trans-Updated-20100207.pdf
