replacement connectors - EFI fuel injector style
PostPosted: Sat Jul 21, 2018 1:16 am    Post subject: replacement connectors - EFI fuel injector style Reply with quote
'Cause I always have a helluva time trying to dig this stuff back out, and maybe someone else wants it too...
Sourcing inexpensive replacements for the connector bodies for the 2-pin EFI fuel injector style connectors we have in many places on our engines - WUR, AAV, Cold start valve, etc... as the plastic connector bodies often crack or crumble, or the rubber boots die...
Key search terms for your preferred electrical parts suppliers are:
Junior Power Timer (JPT) Series
2 position
5mm (spacing)
Allied, Newark, or whoever else is convenient to buy from.
TE Connectivity or AMP are some of the manufacturers, but by no means the only.
963040-3 is one example part # I've found for the body. 282189-1 is another... or 282080 / 282104
The boot is TE Connectivity 880811-2 or similar... I see also a 880810 boot, but it is more expensive, not sure why...
Connector pins are also available, most vendors will show those in the same listings. If you're looking for a complete entire connector with pigtails, pins already crimped in, probably best to get from an automotive supplier...
'79 924 #77 ITB racecar
