The Green 931 -my first transaxle ever (resurrection thread)
Goto page 1, 2, 3, 4, 5, 6, 7, 8  Next
kondzi
PostPosted: Mon Jul 09, 2018 12:15 am    Post subject: The Green 931 -my first transaxle ever (resurrection thread) Reply with quote
As promised, I will post here more info about my 931. I'll try to gradually post some info in this thread, and hopefully few posts later, I'll reach the current state of her resurrection.
So the story is like this - I've never ever driven a transaxle before, but I've heard some stories how good these are in handling corners due to weight distribution. I've already had few not-so-slow classics already, but we all know this feeling of trying something new
So there I'm talking to my friend that had like 20+ transaxles already, including 924, 968, 928, 944... and he's complaining that he has a 931 he wants to keep, but has no time to work on her, as there is something wrong with the engine.
Half a year later he's calling me and asking if I'd take her, as he did literally speaking nothing with the car for a half of year.
Price was good, and overall condition was nice (bodyworks were done by previous owner and some other restoration works as well). The only drawback was the engine - it was knocking, and then it stopped turning...
Anyway I always claimed the worst work is with body works, and I was never afraid of the mechanics.
So here are few photos from rainy December in 2016 when I bought her.
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Mon Jul 09, 2018 12:44 am    Post subject: Reply with quote
Unfortunately during that 6 months, my friend decided to sell pascha door sides, as he said he feels dizzy with that interior... So I needed to search the web and find a missing piece.
It took me about another 6 months to find door sides. There is one thing though, I need to convert from manual to power windows
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Mon Jul 09, 2018 12:56 am    Post subject: Reply with quote
As it just happens I'm trying at the same time to rebuild some cars, and finish my garage construction, the time just flies by.
In other thread someone suggested there is plenty room for car lift im my garage, well indeed there is... a car lift already
So this is how it looks from the outside - as you can see a lot of works still needed to finish my garage.
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Mon Jul 09, 2018 1:01 am    Post subject: Reply with quote
Well at least I'm bit more advanced with my garage and my 931 today. So the photo from my welcome thread once again:
And just from few months ago...
To be continued...
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Mon Jul 09, 2018 2:39 am    Post subject: Reply with quote
OK, so now you're probably wondering this thread should be in other place. Let's get more technical then
So I lift the engine out, put it on a stand.
Let's remove the oil pan...
And have a closer look!
Well to me the 3rd con rod looks a bit wavy, right?
So I took the chance to remove it, and voila!
Believe me or not, what you can see below is the only mechanical damage caused by that con rod to the engine!
At this point I surely started wondering what might have happened to this engine... And honestly at that stage I had completely no idea, zero, nada.
What was the cause of such damage?
I learned that later, few months later, but that's just few more posts to come
Keep track of this thread to lear more soon!
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Mon Jul 09, 2018 2:58 am    Post subject: Reply with quote
Awesome!
Thank you, keep posting!
Hey, I did that yesterday too..
That rod is sweet, definitely a wall hanger..
I am very curious to see what the top of the piston and head look like..
Ahh I see you said it locked up..
PostPosted: Mon Jul 09, 2018 5:41 pm    Post subject: Reply with quote
Really fast accumulation of coolant or oil or fuel in the combustion chamber?
kondzi
PostPosted: Mon Jul 09, 2018 6:12 pm    Post subject: Reply with quote
That was my idea and it's what happened in the end. Air does compress, liquids do not. If engine was running and there was enough fluid inside combusion chamber, with valves closed - there we have it, weakest part fails - con rod.
That would explain no physical demage to valves, cylinder and piston.
The question remains - what was the fluid, and where did it get from.
Head gasket was in mint condition when removed, so it was not coolant...
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Mon Jul 09, 2018 9:44 pm    Post subject: Reply with quote
Massive leak of the injector?
Guy started the car with foot on the throttle, there was a lot of gas in the chamber...?
kondzi
PostPosted: Tue Jul 10, 2018 2:10 am    Post subject: Reply with quote
You're right it was gasoline! Before I get to that, explaining what exactly caused this leak, let's see how crankshaft rotates with replaced conrod
https://www.youtube.com/embed/O7Q4hJR360U
Well it rotates fine!
So I took the regular road - stripped down the engine, starting with removing the head and so on...
As I was planning to do a full rebuilt with new seals and gaskets (got the Victor Reins ones, as the genuine Porsche were twice as expensive :-/ ) I just gave cylinder block and head to machining shop so they could earn some bucks as well.
They did all those things I cannot name in English
So in general I received refurbished head with everything matched and in place, resurfaced cylinder block to fit new head gasket and so on...
I really like assembling engines with manual in one hand and set of proper wrenches and sockets!
End the engine looks like that now:
I'm still far far away from my 931 CIS journey... That is still on unfortunately.
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Tue Jul 10, 2018 2:20 am    Post subject: Reply with quote
So I managed to put the engine back in the car
Using my custom built engine lifting bracket for more precision handling
I think US/Canada cars had some kind of exhaust recalculation valve or so here, in EU specs there is just place for two bolts that I used for balancing the engine.
BTW where this thing goes???
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Tue Jul 10, 2018 2:51 am    Post subject: Reply with quote
My CIS journey begins...
Before I cranked the engine for the first time I did some checks.
Injectors were just rubbish, there was nothing like spraying pattern by single one of them. Replaced with new ones, learned these are the same as in 965 3.3 Turbo/
Fuel filter... Well it looked like the one installed in factory?
It took me a while to figure out where I can get the replacement filter from, and it seems BMW E21 is a direct replacement!
Finding this filter by Porsche PET numbers is a nightmare...
Then I bought new spark plugs, wires, distributor cap and rotor...
I was really positive before cranking the engine. Although the pressures were not there yet with WUR, but I've done that on some 911 already. BTW I hate WUR location in 931 I ended up removing it and using extension fuel lines with the dial ad it was not possible to do any set-up.
And there it is, the reason of a bent rod...
It was not the injectors, nor the fuel pump, nor the WUR. The fuel distributor was letting through fuel to injector #3 all the time there was pressure in the CIS. It was literally flooding the combustion chamber.
My assumption is that at one moment when engine was running on 3 cylinders, the amount of gas in combustion chamber was growing to a level when it was rock solid fluid between piston and head with closed valves and bump! Here we have a bent rod.
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Tue Jul 10, 2018 3:00 am    Post subject: Reply with quote
If you have a hole in your head there under your custom lift point I think that is for the latest 931 cars that had an updates turbo drain and crankcase breathing system..
This is the turbo drain part..
I suspect that you're confusing the "head breather update" with the "crankcase breather".
The crankcase breather is standard on all the 2.0L, turbocharged or not, and uses the same insert on the block, just under the intake manifold (hard to see and get to with the engine in situ). The only difference between the NA and the 931 is that the NA has a restrictor in the hose; in both cases, the hose from the breather port is plumbed into the airbox (although the routing is obviously a little different due to the different design and locations of the respective airboxes).
The "head breather update" went through at least three iterations, and is unique to the 931. The theory I have seen postulated is that the original turbo oil drain was prone to clogging due to the oil getting aerated due to poor head breathing; the foamed oil would congeal and turn into sludge in the oil drain, and eventually clog, leading to premature bearing failure in the turbo.
The so-called head breather update was added to assist in aspiration/air-oil-separation of the drain setup by allowing vacuum from the head to be drawn on the oil drain line. There is a port on the side of the 931 head that has a hole in it, with a cover plate and metal elbow welded on. A variety of small rubber elbows and straight hardline sections connect the head breather port to the turbo drain assembly. As noted, there were at least three variations of the oil drain setup + breather setup. The S1 had no head breather and a fairly simple drain line. The S2s had two different iterations of the drain line with a funky metal box that forms a Y from the oil drain and the head breather port. I don't recall the exact nuances between the two versions, but there were definitely two different arrangements of this setup.
FWIW, my 81 Euro has the latest iteration; I have also seen S2 cars with the middle iteration, and I have seen S1 cars with the latest iteration. I believe this is because these updates should have been performed by a dealer-maintained vehicle at the prompting of a Porsche Technical Service Note.
As for the turbo hoses, here is a comprehensive list of the elbows that need to be replaced:
  • elbow at head breather plate
  • elbow to vac limiter
  • elbow from AAV
  • elbow from tube under the hard pipe to the vac limiter
  • elbow from the back of intake manifold
  • On the S2, there is another elbow off the charge tube; on the S1, this piece is not an elbow, but a 18x26, 48mm straight section
  • Another 18x26, 48mm to AAV
  • elbow from the integral bypass valve on the compressor housing (this item is now NLA from Porsche)
(Aside from the last item, all of the above are included in the 931 Vac Elbow Kits that I offer on my website).
If you don't have all of that maybe your head is from a car that did or something..
kondzi
PostPosted: Tue Jul 10, 2018 3:22 am    Post subject: Reply with quote
So I got a replacement fuel distributor from my friend, and I was so happy all should go fine now. Spraying patterns like in catalogue, even amount of fuel in all four injectors...
https://youtu.be/kZmhpwkb5ho
The thing was, at that stage I was not getting any change in fuel pressure when the WUR warmed up.
So I stripped it down.
Don't have a photo of that, but the bi-metal spring was mounted up-side down.
Having the WUR in hand I decided to convert it to adjustable WUR by installing a bolt, washer and a nut in cold pressure regulation barrel.
And I need to add here, every job I do on this car is during a weekend, at my parents summer house, which is roughly 125 miles from the place I live and work, so getting from one stage to another takes me roughly a week or two...
So I thought - finally I nailed it! Next weekend I'll get a clean engine start and finally after year and a half I will have a ride with my 2016 Christmas present!
And I was so wrong about it... So wrong...
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Tue Jul 10, 2018 3:31 am    Post subject: Reply with quote
Well for sure there is something messed around with that engine. Just to mention I have the early shaped pistons and DITC that came much much later... I definitely don't have a hole in the head there under my bracket, but the setup around the oil pan looks as mine.
Konrad
'89 951 US
'81 931 RoW (TBD)
Page 1 of 8
