Is there a 931 S2 ignition distributor replacement ?
PostPosted: Sat Jun 23, 2018 5:09 am    Post subject: Is there a 931 S2 ignition distributor replacement ? Reply with quote
Th distributor look like a normal distrubor where the inside had been removed.
Can you use a 924 na (or other car)ndistrributor, empty it, and use for a 931 ?
Johann
PostPosted: Fri Jul 06, 2018 12:40 am    Post subject: Reply with quote
Yes, that should work without a problem.
