Interesting M471 stuff..
PostPosted: Sun Jun 10, 2018 5:20 am    Post subject: Interesting M471 stuff.. Reply with quote
Check this out..
http://16vt.free.fr/931/Porsche%20924%20Turbo%20Service%20Info-1.pdf
Did you know that the M471 has a different steering rack?
It says the standard ratio is 20.87:1 and the M471 is 22.1:1
Interestingly it also says that the rear disks and calipers are 928 parts, the front disks are 911 parts, front wheel bearings are 911 parts, and the front calipers are 928 parts..
M471 steering knuckle has a 6,5mm longer steering arm
M471 rear camber is different..
The manual calls for 20/50 engine oil
PostPosted: Sun Jun 10, 2018 6:35 am    Post subject: Reply with quote
Yes Sir......that's why they are special and becoming increasingly rare!
Cédric
PostPosted: Sun Jun 10, 2018 7:41 am    Post subject: Reply with quote
I think the rack is the same, but the slower ratio comes from the longer steering arms in the spindle. Thankfully the parts are shared, hence discs etc are reasonably priced and many racing pads are available. Im glad all 931s have that setup over here the manual have always recommended different viscosities for different climates, most of those specs are outdated, no need run a 20w50, except if you don't want oil to be pumped around when your engine is cold.
´80 924 Turbo
PostPosted: Sun Jun 10, 2018 7:46 am    Post subject: Reply with quote
That makes a lot of sense.
PostPosted: Mon Jun 11, 2018 1:21 am    Post subject: Reply with quote
That’s just a full sugar RoW turbo for us. You guys over the pond got strangled motors, 4 lug hubs etc. So essentially the sugar free version unless you paid extra for the full fat
Cédric
PostPosted: Mon Jun 11, 2018 4:54 am    Post subject: Reply with quote
I assume the 4 lug was to compensate all the additional emission stuff, otherwise it would be hard to get any profit at all on a small volume car like the 931.
´80 924 Turbo
bunta
PostPosted: Tue Jun 12, 2018 8:23 am    Post subject: Re: Interesting M471 stuff.. Reply with quote
Fasteddie313 wrote:
Check this out..
Hi
How did you found this link ?
This is my ftp
PostPosted: Tue Jun 12, 2018 9:37 am    Post subject: Re: Interesting M471 stuff.. Reply with quote
bunta wrote:
Fasteddie313 wrote:
Check this out..
Hi
This is my ftp
FTP? I don't recognize the acronym..
I became aware of a Porsche .pdf on a variation of the free.fr site so I snooped around it some more and found a bunch more interesting manuals there..
Their is also a 931 S2 manual + others..
Edit: Ah, I see this is your site..
I hope you don't mind.. Subbed to your YT too..
PostPosted: Tue Jun 12, 2018 11:00 pm    Post subject: Re: Interesting M471 stuff.. Reply with quote
Fasteddie313 wrote:
bunta wrote:
Fasteddie313 wrote:
Check this out..
Hi
This is my ftp
I guess that makes us old...
'79 924 #77 ITB racecar
