Kenodog
Posted: Thu May 31, 2018 11:21 pm Post subject: *URGENT* Info Needed Please |
I got a call from the shop building Olive's new motor and the mechanic asked me for the diameter of the rod and block bearing surfaces. I have the journal diameters but he needs the OD sizes where the bearings fit onto. The factory manual does not state this info and I cannot actually think why he would need it except to be able to calculate bearing play...
Anyone ?
Lee _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Posted: Thu May 31, 2018 11:30 pm Post subject: |
Somebody with an open block may be able to help if they had the caps and the right measurement equipment.
I can get you the rod big end diameters(where the bearings go) but I cant help you with the block dimensions. _________________ https://www.the924.com |
Kenodog
Posted: Fri Jun 01, 2018 12:41 am Post subject: |
Thanks brother that would be helpful. The only reason I can think he would need this is because of the clearance tolerances for the bearing caps. Never been asked this before.
Leg _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Brockoli
Joined: 06 Feb 2007 Posts: 621 Location: Edmonton, Alberta, Canada
Posted: Fri Jun 01, 2018 12:47 am Post subject: |
I have my '79 block that I could measure. The block was align honed when I rebuilt it. Not sure if that makes a difference. I only have calipers to measure. Would that be accurate enough? _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting) |
Kenodog
Posted: Fri Jun 01, 2018 1:21 am Post subject: |
Thanks guys but I found the info. Helps to have your glasses on when reading tech manuals lol !
Leigh _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
