Noahs944
Joined: 08 Dec 2015 Posts: 782 Location: Calgary, Alberta, Canada
Posted: Thu May 17, 2018 2:49 pm Post subject: |
snakoil wrote: | what color will you go with?
Since this was my first body prep for painting I went white to hide all mistakes I assumed I made...and man did I do a few! |
Hah! Yes, body work & paint is HARD to achieve good results from, especially when you are trying to figure it out by yourself in the garage!!! You made a great choice by going with white. I'm still undecided. |
Noahs944
Posted: Sat May 19, 2018 4:01 am Post subject: |
Well the chaos has began here at Wilson Racing headquarters. I have runs on the hood because the wind blew it (later I put an anchor on the hood). So I will have to wait and sand. I clearly see tons of dents & scratches on the hood. I shouldn't have taken it down to the metal. Yeah, this is going to be another "race day" paint job... not a good paint job. |
Noahs944
Posted: Sun May 20, 2018 6:48 am Post subject: |
Welded in a new nose panel piece to replace the damaged one. Also, this is the pretty colour Wilson will be!! |
Noahs944
Noahs944
Posted: Mon May 21, 2018 1:51 am Post subject: |
Fuel cap lid delete. gonna run the Sparco through the window. |
Noahs944
Posted: Mon May 21, 2018 3:09 pm Post subject: |
Finally Painted! |
Noahs944
Posted: Tue May 22, 2018 4:07 am Post subject: |
Voith, Thanks so much brother! I really am feeling grateful to be at this stage. It's been difficult to get motivated. But now I can be enthusiastic!... I'm so happy with the colours... this is my dream car!
Noahs944
Posted: Tue May 22, 2018 12:47 pm Post subject: |
Scott! Many thanks for your compliment. I aimed to make a pretty solid cage that would allow me to engage in "seriously fun times"... whatever the occasion. The car is now equipped with 1.25" (250 lb/in) front springs and 28mm rear torsion bars and Bilstein shocks and oem sway bars. For gravel I always felt oem North American ride height was pretty much on the mark. But those days are over (for Wilson) and now the purpose is #1) daily driver #2) autocross #3) big track days (not door to door racing so much as educational days for me).
I really wish there was tarmac rallies here but there is only 1 really awesome event, annually... but that's across the country. So in the meantime I plan on honing my skills in the early mornings. My passion is curves & corners and so I built this car for slow-medium speed corners! Note: I wish we lived closer so I could come over & bug you for driving tips!
The picture above makes me so happy with how the vents look aesthetically. It was a risk I took by going a bit unconventional, however I have read a bit about a really fast 951 from back in the day that merely used louvers in a similar fashion). Personally I envisioned a better air flow design (which is why I "v-mounted" the radiator in the first place), but found later I ran out of room in front of the engine to channel the "thru air" in the manner I wanted to. Additionally I need to consider air borne particles that can enter the timing belt region, since I'm running sans-timing belt cover and thought louvers should do the trick.
Pic below: The receptacle for the window net. It can be a bit of a head banger if not paying attention upon ingress/egress. I wont be using theses often and wonder if someone makes a "pad" to clip on when not being used?
Noahs944
Posted: Wed May 23, 2018 12:03 pm Post subject: |
You guys have your hearts in the right place, and your familiarity with race cars and 944 vehicles gives you credibility. There is something you haven't considered however; I built this cabin area *custom* for my intended purpose on daily driving without a helmet! All features of the cage is kind to legs & knees & head. Remember the seat is FIXED and back much further than stock (inspired by a modern Subaru pro level rally car). The pedals are modified 3" rearward, shifter is up and back & the steering wheel is like 4+" rearward. Please consider this. Its a different dimensional "fit" then an off the shelf 944 race car cage & seat.... which is why it took so long to massage everything into place. Mind you, I think I need to pad the throttle pedal a bit more.
So, I don't mean to be argue-mental... but for ****s sakes I built the car for my intended purpose, and since you guys are not coming around to my garage with your measuring tapes, I'd like to leave the "safety concerns of a street driving race car" out of this thread, because I KNOW BETTER than anyone. I sweated hard to make this sucker work.
Oh, and managed to retain air conditioning |
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Wed May 23, 2018 9:55 pm Post subject: |
You and I have very different definition of daily driving!
but coudos on the clean install, I do like the pedals _________________ 1979 924 NA |
Posted: Thu May 24, 2018 2:24 am Post subject: |
I like the color a lot and them louvers do look pretty darn good..
I think I remember reading about engine controllers you will be running, obviously they will be working with your dash pod thing, and that is pretty sweet.. _________________ 80 Turbo - Slightly Modified |
Noahs944
Posted: Thu May 24, 2018 11:27 am Post subject: |
I'll just leave this here... hopefully end the cage discussion. Her credibility is far FAR greater than probably anyone on this board. Unless you fellas have won a world title in Rally during the Group B years. https://www.youtube.com/watch?v=Zp8QkyXyTrc |
Noahs944
Posted: Thu May 24, 2018 11:30 am Post subject: |
Fast Eddie, that center console could be a replacement for the oem instrumental cluster, but NOT engine management. I decided to keep the oem cluster though so this will provide other information for the operators only (like temperatures, lap times, clock, etc. |
Noahs944
Posted: Thu May 24, 2018 11:33 am Post subject: |
Snakeoil,
Many thanks! The hydraulics need to be completed before I can tell if the change in pedal swing ratio is acceptable... since the pedals were extended, it changed the ratio unfortunately. |
Noahs944
Posted: Sat May 26, 2018 10:45 am Post subject: |
Brother, yes the concern of head trauma was the #1 reason why I moved the seat as far back as reasonable. With the old set up (higher seat, less layback, 3" forward of what you see here), I felt it was too close... but with the current setup, once locked in with harness... that bar is a long way from the head.
Regarding Turbo stuff, I hope to start working on engine items within 2 weeks & will update. I made a mistake with is going to be a b*tch to correct, but doable.
Side note: but having the seat rearward it also makes the car easier for ingress/egress. Its still a workout, but the door bars turned out exactly as I had wished to help the occupants slide in and out. |
