ANYONE DOING ANYTHING EXCITING ON THEIR CAR ?
Goto page Previous  1, 2, 3 ... 134, 135, 136 ... 140, 141, 142  Next
PostPosted: Tue May 15, 2018 5:26 am    Post subject: Reply with quote
Thanks bro. It was unexpected for me as well.
I will write an article about my crash, my 924 life and my getting out of the 924 scene. It will probably be featured in the UK 924 owners club magazine but i'll make it available to this board as well under some form.
red 924 and not red 924
PostPosted: Fri May 18, 2018 6:44 am    Post subject: Reply with quote
I found my distributor hold down bracket!!
Noahs944
PostPosted: Sat May 19, 2018 12:27 am    Post subject: Reply with quote
Morghen, did you sell your car to Magnus Walker?
PostPosted: Sat May 19, 2018 9:07 am    Post subject: Reply with quote
funny, no i did not. He bought a GT and painted it the same colors that my 931 had.
Ozzie
PostPosted: Sun May 20, 2018 10:06 am    Post subject: Reply with quote
just done the tie rods and ball joints. waiting on a steering shaft and will be back on the road.
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Thu May 31, 2018 8:05 am    Post subject: Reply with quote
Learning to appreciate and photograph this thing
Kenodog
PostPosted: Thu May 31, 2018 10:47 am    Post subject: Reply with quote
Oh ! It's THE Cayman in Romania, lol
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kid's limo)
2008 GS500
1996 Dodge Caravan (DJV)
PostPosted: Thu May 31, 2018 4:08 pm    Post subject: Reply with quote
Very nice car!
937 DITC
Mr Bitey
PostPosted: Tue Jun 05, 2018 8:09 pm    Post subject: Reply with quote
Check out my cribs
It is amazing how solid this is.
Parts car in it's current state:
Tom
___________
1979 924 NA
1979 924 NA - Parts car
macBdog
PostPosted: Wed Jul 04, 2018 1:37 pm    Post subject: Reply with quote
It's been rough getting workshop time but last weekend the stars aligned: car shop sale, clear weather, missus away at a hens.. GAME ON
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
jacobroufa
PostPosted: Wed Jul 04, 2018 1:55 pm    Post subject: Reply with quote
Rear passenger wheel cylinder had a tiny a leak that turned into a flood a couple weeks ago so I took the opportunity to replace both rear cylinders and rubber hoses (the hard lines are in great shape but the rubber was a bit stiff...), and the shoes on the side that burst. Brake fluid is a pain in the butt to clean up... While I was back there I replaced the rear shocks as well. That was a good project for today and thankfully the FLAPS had the right shoes even though their website said it wouldn't fit. Works fine... \_(ツ)_/
Since I've already cracked open the brake system and have to bleed it anyhow, I am going to also replace the front brake hoses as they're as stiff as the rears, and do a flush. I hope to get this done before the weekend so I can have some fun driving it. I also got front struts and new strut tower bushes (yay VW fox for being the same at 1/10 of the cost!) so I will maybe get that done while I'm in there.
I also have a new rear hatch seal (thanks Ideola!) and plugs/wires/distributor cap and rotor to install, but that's pretty trivial by comparison...
I'm really looking forward to driving this thing with a solid brake pedal and actual damping for once!
Mr Bitey
PostPosted: Tue Jul 10, 2018 8:08 pm    Post subject: Reply with quote
Awesome pics!!
My missus has assigned me gardening duties this weekend! So frustrating!
Tom
___________
1979 924 NA
macBdog
PostPosted: Mon Jul 30, 2018 3:06 pm    Post subject: Reply with quote
Don't you hate that!! I thought I was getting roped into IKEA this Sunday but instead, I got left at home yessssss.
The tops and sides of the cage are now fully welded, primed and ready to be painted. I was psyched to be able to get the cage low enough to get the tops welded confidently. Also psyched on spending the time experimenting to dial in overhead welding. It's always been a bit of a mystery to me but now I know how much extra arc force and wire feed is required. I know it was all part of the plan but execution is always it's own beast. I ended up using a beefy ratchet strap to pull the A pillars in tight enough to fit between the front footwells. Then the whole shebang could slide forward and downward about 300mm.
I could see the weld puddle all the way over the top then I used a USB camera/boroscope to check the welds and ended up having a dream about a race scrutineer finding a crack with an inspection mirror. Double checked this morning and found a pinhole that I will grind out and reweld so thanks subconscious me! The cage is now backin situ and some clamps are pulling the A pillars back into line.
Progress pics in reverse order:
Also adjusted the valve lash, installed a remote oil filter boss and new rocker cover gaskets:
1973 911E with EFI
p-talk wrote:
Eric P
PostPosted: Wed Aug 01, 2018 2:05 am    Post subject: Reply with quote
I made a trip up to the mountains for the weekend with my 924S. I wanted to go kayaking with my new lady friend, but she had no way to transport a kayak. Not to worry, my mighty TwoFa is up to any task!
Over 800 miles all said and done and not so much as a hiccup.
1980 924 NA, US model
1987 924S, US model
PostPosted: Wed Aug 01, 2018 6:00 am    Post subject: Reply with quote
nice !
Page 135 of 142
