musicalannette
Posted: Thu May 10, 2018 2:28 am Post subject: fron rear axles weights? |
Hi.
One thing I didn't do I meant to do before the car was written off was take it to a weigh bridge.
Does anyone have the weight of the car front in kg's and rear in kg's.
Jus by driving each end on to a weigh bridge?
I thought this might be slightly different for different models and gearboxes.
Thanks. _________________ I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737..... |
Joined: 29 Jul 2001 Posts: 8813 Location: Royal Oak, MI, USA
Posted: Thu May 10, 2018 10:03 pm Post subject: |
Additional info... note that the scale numbers posted are without driver, gutted car with cage, approx 3/8 tank of fuel. Things even out side-to-side better with the driver installed.
Also note that we've typically found the racecar to be 49/51% front/rear bias, due to the lack of interior... whereas when I scaled my 82 931 ages ago I found it more like 51/49% front/rear - though at the higher weight with interior etc.
HTH... _________________ Vaughan Scott
