Weight considerations - OEM 14" vs Three piece 15"
XLR8
PostPosted: Fri May 04, 2018 4:32 pm    Post subject: Weight considerations - OEM 14" vs Three piece 15" Reply with quote
Hi all,
I have two sets of tyres/wheels options for my '82 NA (see below - getting new tyres soon).
The car runs standard springs, OEM dampers and 968 sway bars. It handles very well now with 14" wheels.
However, I am seeking advice on whether the additional rotating weight of the 15" wheels will more than offset the otherwise better handling of the bigger wheels and wider tyre?
Or am I being pedantic here .....?
The two tyre wheel options I have are below:
14x6.5J "Original "Tarantula" alloys - 6.5kgs (14.3lb) each (excl 195/65R14 tyres)
15x7J Three piece alloys - 8.0kgs (17.6lb) each (excl 205/55R15 tyres)
Thanks in advance!
'81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100
CÚdric
PostPosted: Fri May 04, 2018 5:08 pm    Post subject: Reply with quote
Weight isn't such a big issue, but the total diameter is. Try to keep it as low as possible, it really makes a significant difference in acceleration due to the gearing differences.
But on lap time wise you will definitely win with the new setup. Just by the best tyres you can afford.
XLR8
PostPosted: Fri May 04, 2018 7:43 pm    Post subject: Reply with quote
Cool. The suggested tyre sizes have the same diameter.
OK, sound advice. Thank you.
'81 Porsche 924 NA
