porsche 924 1977 fuel accumulator problem
phillipbpruitt
PostPosted: Tue Mar 27, 2018 7:12 am    Post subject: porsche 924 1977 fuel accumulator problem Reply with quote
question about fuel accumulator on a 1977 924
Took out both set screws, both are leaking fuel.
Could that cause the car to start for a few seconds and then die.
My theory is, that the Cold start injector is holding fuel pressure, once it turns off the car canít hold pressure causing it to die!
I dont have a cis pressure tester, but i heard that if the set screws leak fuel, then the diaphragm is broken
Eric P
PostPosted: Tue Mar 27, 2018 7:21 am    Post subject: Reply with quote
If fuel comes out when you remove the screw, you need a new fuel accumulator. I believe Porsche updated this so that there was 1 40cc fuel accumulator instead of two 20cc fuel acumulators. If you know they need to be replaced, I would start there.
Typically a bad accumulator will cause hot start problems because the fuel pressure leaks down too quickly. It may cause other issues as well.
Have you tried pulling the fuel injectors (put the tips in fuel resistant bottles) and jumpering the fuel pump relay? The injectors shouldn't flow until you lift the flow plate. Don't attempt to turn the car over until you know that you're not flooding the cylinders with fuel. It's common for the o-rings in the fuel distributor to tear. 3/4 of the o-rings in my car were bad when I bought it. The car would start but it would only run for a second or two and flood out. Luckily the previous owner gave up before he bent a rod.
1980 924 NA, US model
1987 924S, US model
phillipbpruitt
PostPosted: Thu Mar 29, 2018 5:30 am    Post subject: Reply with quote
I think Iím flooding the car with fuel, because itíll start for two seconds then die. So I keep restarting it and itíll do it until I flood it out by constantly starting it.
I replaced the fuel distributor, warm up regulator, all the fuel injectors spray evenly etc.
I do need to re run some vacuum lines, but the car was running without them.
So far both fuel accumulators leak. Both of them. I figured it would be losing fuel pressure once, the cold start injector shuts off because the diaphragms arenít holding anymore.
Because regardless fuel is running through them constantly!
Eric P
PostPosted: Thu Mar 29, 2018 5:51 am    Post subject: Reply with quote
Start by fixing the issues you know of. Don't proceed with trying to start it until you've sorted those issues.
You need new accumulators and you need to fix your vacuum lines. Any troubleshooting with these known issues is pointless.
Once you have that sorted, make sure that your injectors are only spraying when the flow plate is lifted. Pull the injectors out of the head, put the tips in fuel resistant bottles, jumper the fuel pump relay. Check that the injectors aren't leaking, dribbling, or spraying until you lift the plate.
Fix your known issues and do your basic maintenance first. If you think you're flooding the engine, don't turn it over until you fix it. Cranking a flooded engine can cause major damage to your engine (blown gaskets, bent rods, seized rod bearings, etc.) Does your oil smell like gas? If the answer is yes, you're flooding it.
1987 924S, US model
jrobinson
PostPosted: Fri Apr 13, 2018 5:52 am    Post subject: I have same problem Reply with quote
Hey guys,
I have the exact same problem. I have replaced both accumulators. I have fixed all vacuum leaks. I replaced the fuel pump. I have cleaned out all fuel lines. I am NOT getting fuel out of all injectors ( new ). I must now assume I need to rebuild, or replace the fuel distributor. This has been the most frustrating problem to overcome ( assuming I will overcome it someday!) I'm open to suggestions. Car starts pretty easy but dies after a few seconds.
Jason Robinson
1978 924
agfisher
PostPosted: Sun Apr 22, 2018 12:16 pm    Post subject: Reply with quote
Have you unscrewed the injectors and checked if you are getting fuel to the injector? How about removing the fuel supply line to the distributor and jumper it the fuel pump. See if fuel is getting to the distributor.
Adam
1977 924 N/A Martini Edition
