How to Install a Rear Sway Bar on a 924 without one
Goto page Previous  1, 2, 3, 4, 5
PostPosted: Wed Mar 18, 2015 5:32 pm    Post subject: Reply with quote
Wow !
You should not modify this car. Sell it to someone that wants to keep it original and get a later model.
chris79
PostPosted: Wed Mar 18, 2015 9:21 pm    Post subject: Reply with quote
Why ? I read that sway bar was optional in 924 na before '78
chris79
PostPosted: Wed Mar 18, 2015 11:18 pm    Post subject: Reply with quote
Can anyone post some photos of bottom 924 na ?
PostPosted: Wed Mar 18, 2015 11:21 pm    Post subject: Reply with quote
you should make a new topic for your car, moderator should move all these posts to your topic...we are polluting a how-to topic.
chris79
PostPosted: Thu Mar 19, 2015 12:10 am    Post subject: Reply with quote
if I create a new post they tell me read how to, I'll have to write somewhere ?
Chrenan
PostPosted: Wed Jun 10, 2015 7:20 am    Post subject: Reply with quote
I'm disgusted to have come back and seen the mess made of my how-to thread. This is how content contributed by senior members is treated? I demand retribution.
Brockoli
PostPosted: Wed Jun 10, 2015 7:50 am    Post subject: Reply with quote
Rare Chrenan sighting!!!! O no, I'm also polluting the thread
XLR8
PostPosted: Sat Mar 10, 2018 9:17 am    Post subject: Finally put a rear sway on my '82 NA. Reply with quote
I found a pair of used 944 S2 Sways (27mm front, 18mm rear) and have only managed to get the 18mm rear bolted in so far.
The car has a 21mm front installed from factory (and for the moment, still does).
She's gone from understeering on power in tight turns to quite dramatic oversteer (tight and medium turns) - even with <125bhp! She would be a handful in the wet!
I plan to install the 27mm front, which I think will even things out a bit. My seat of the pants thinks that a 16mm rear would be an excellent match for the standard 21mm front.
'81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100
XLR8
PostPosted: Wed Apr 11, 2018 9:14 pm    Post subject: Reply with quote
Finally got the 27mm sway bar on the front (18mm already installed in the rear). I installed some Poly main bushings at the same time.
What a transformation! Steering is quicker, muuuuuch flatter cornering, and cornering potential is way faster. Highly recommended.
'81 Porsche 924 NA
Post new topic   Reply to topic    924Board.org Forum Index -> How-To All times are GMT + 11 Hours
Page 5 of 5
