Nersinho
Joined: 12 Oct 2017 Posts: 13 Location: Guimaraes, Portugal
Posted: Tue Apr 03, 2018 4:22 am Post subject: |
thanks. have a 4 bolts. year 1981 january.
but the engine 924 turbo in portugal is very hard find it and have 170hp. i buy 944 complet 2000 eur. and my idea is aplicate turbo. but i need one person help me modify... complicated... |
Posted: Tue Apr 03, 2018 4:36 am Post subject: |
2.5L is not good for direct turbo....you need to spend a lot of money to get that engine ready for turbo.
Also to get the 2.5 in your 924 is a VERY big project. _________________ https://www.the924.com |
Posted: Tue Apr 03, 2018 4:50 am Post subject: |
For only 250hp why not turbo charge the standard engine? Its been done before successfully. Probably much less work than changing to the 2.5. _________________ 1980 924 Turbo
Posted: Tue Apr 03, 2018 5:01 am Post subject: |
Nersinho wrote: | have a 4 bolts. year 1981 january. |
Honestly, you pick the wrong car to build a GT replica.
It would be much easier to swap all you body parts on a 924 turbo with 5 bolt.
Nersinho wrote: | i buy 944 complet 2000 eur. and my idea is aplicate turbo. but i need one person help me modify... complicated... |
Very much complicated, this is what we are trying to tell you.
In fact, way to much complicated....
How deep are you pocket?$$$ _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
Nersinho
Posted: Tue Apr 03, 2018 5:03 am Post subject: |
is sucefull turbocharger engine standart? when i see one project? |
Nersinho
Posted: Tue Apr 03, 2018 5:07 am Post subject: |
I already spent 2000 in 944. Now with over 2000 I wanted to party ... |
Nersinho
Posted: Tue Apr 03, 2018 5:21 am Post subject: |
one question. the my engine in not totaly porsche. the turbo is 100% porsche? |
Posted: Tue Apr 03, 2018 6:14 am Post subject: |
The 924 turbo is similar engine to yours, still 2L.
2.5L is 100% Porsche engine.
unfortunately for 2000 you cant get 250HP..not from the 2.5L engine.
For 2000 you can get belts and a good front end service on the 2.5L _________________ https://www.the924.com |
Nersinho
Posted: Tue Apr 03, 2018 6:25 am Post subject: |
It's ok. I thank you for all the answers you gave me. so if I fall I'll apply a turbo to my standart. but I should buy some pistoes right? no ebay ha? then I buy a turbo. I have to go to a tuning company? and the injectors? |
Posted: Tue Apr 03, 2018 3:41 pm Post subject: |
Nersinho wrote: | It's ok. I thank you for all the answers you gave me. so if I fall I'll apply a turbo to my standart. but I should buy some pistoes right? no ebay ha? then I buy a turbo. I have to go to a tuning company? and the injectors? |
Its sad that most pictures are now down, but this guy knows how its done.
http://www.924board.org/viewtopic.php?t=38765
Raceboy on this forum also built a strong turbo converted 2.0.
http://924board.org/viewtopic.php?t=21735&postdays=0&postorder=asc&start=0
Both use a standard 924 engine as far as I know, but of course it involves fabrication for the turbo piping and also for the fuel injection. The clutch will also need to be upgraded. The key is to have a good setup with a modern turbo, (Mitsubishi TD04 #6 exhaust housing, 18t compressor is a very good option), large intercooler and most importantly someone very competent who does the engine calibration. _________________ 1980 924 Turbo
