farmer
Posted: Sun Mar 04, 2018 5:17 am Post subject: Flywheel sensors |
I posted this in the wrong forum possibly. Ill try here
New flywheel has 1 sensor. Old flywheel has three. Now what?
Thanks for any help. pqa |
KDJones2000
Posted: Sun Mar 04, 2018 7:10 am Post subject: |
You need to share quite a bit more about your car if you want anyone to help you.
Year, model, etc. will go a long way... Put it in your signature, in fact _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
farmer
Posted: Sun Mar 04, 2018 7:22 am Post subject: Did my signature |
Ok. Thanks.
Its a 1987 924S. The clutch was the rubber type and it wasn't so much wore out but the rubber had deteriorated. The flywheel looked be warped some so I ordered a new one. My friend (GM Technician) doesn't like aluminum. We believe it would bolt up but the two sensors are missing. _________________ 1987 924S No mods.
175000 miles.
No racing just a love for driving it. |
farmer
Posted: Sun Mar 04, 2018 8:19 am Post subject: |
Upon further inspection the new flywheel is 10 and 15/16 inches and made of aluminum.
The original is 10 and 7/16 inches and appears to not be aluminum. It is magnetic. Technician is not a fan of aluminum.
Where do I buy the right one?
TIA _________________ 1987 924S No mods.
175000 miles.
Posted: Sun Mar 04, 2018 8:47 am Post subject: |
If you can't resurface your old one, I will have a used one available in few weeks.
PM me for more detail if interest _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
KDJones2000
Posted: Sun Mar 04, 2018 1:00 pm Post subject: |
OEM is steel, not aluminum.
Any 944 flywheel will work on your 924S.
Keep in mind that you can typically resurface these flywheels once, and then they are done. Look at the shop manual and you will see what I mean.
You really only need one sensor point on your flywheel, as the second one is only used for the Por$che dealer TDC sensor.
You have a reference sensor that uses the sensor post, while the speed sensor uses the teeth on the starter ring. _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
