FS: 924 Flywheels and Clutch Discs
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale
Britain
PostPosted: Tue Feb 13, 2018 4:30 am    Post subject: FS: 924 Flywheels and Clutch Discs Reply with quote
I have the following 924 Flywheels and Clutch Discs for sale:
Flywheels:
Left - S2 Flywheel. $200
Right - S1 Flywheel that has been machined to reduce weight. If I recall, we took off some ~10lbs or so. $150
Clutch Discs:
Both of these discs were custom made by Kennedy Engineering with 931 splines (won't work on 924 N/A torque tube shaft). These are high quality discs that worked very well for us after multiple failures from SACH discs.
Left - Brand New (SOLD!)
Right - Used ~1000miles $120 (Pending)
Prices do not include shipping. Paypal preferred.
-Britain
Britain
PostPosted: Wed Feb 14, 2018 4:26 am    Post subject: Reply with quote
New Clutch Disc Sold. The 2nd clutch disc is still available and basically brand new.
-Britain
lordam
PostPosted: Thu Feb 15, 2018 10:49 am    Post subject: Reply with quote
You have PM on the second clutch
1981 931 ROW RHD Australian delivery, Bilsteins, LSD, adj coilovers, #225lb/in front, 27mm TB
MugenRep
PostPosted: Sat Feb 17, 2018 3:02 am    Post subject: Reply with quote
Hello,
S1 Lighter flywheel? Am I correct it's for the Audi 2.0 SOHC with Audi 4 or 5 speed transmission? Or am I incorrect and this is for the G16/G31 trans?
Also stock S1 flywheel weight vs. this flywheel?
THANK YOU!!!!
1979 Porsche 924s with the beloved 915-based dog legged 5 speed.
Britain
PostPosted: Fri Mar 02, 2018 8:37 am    Post subject: Reply with quote
Here are some better pictures of the flywheels after running thru the parts washer. Both are still available.
The S1 Flywheel (without timing teeth) was lightened to 12.5lbs.
The S2 Flywheel is stock and weighs about 12.5lbs or so.
They both have good pilot bearings in them.
Britain
PostPosted: Fri Mar 02, 2018 8:38 am    Post subject: Reply with quote
MugenRep wrote:
Hello,
THANK YOU!!!!
I believe that these will only work on turbo cars. Someone else who is more knowledgeable would have to chime in.
-Britain
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale All times are GMT + 11 Hours
