# RoW 931 porn!!! NWS warning ... (not wallet safe!)
Goto page Previous  1, 2, 3 ... 28, 29, 30, 31  Next
canyonblaster
PostPosted: Fri May 06, 2016 10:37 am    Post subject: Reply with quote
I am seeking new clears for my newly installed euro front bumper!
Who can help??
https://www.flickr.com/photos/65830420@N05/albums
PCA Licensed Club Racer & Driving Instructor, Current cars: 1981 931, 2005 996 GT3, 2013 Cayenne GTS
PostPosted: Mon Jul 18, 2016 7:03 pm    Post subject: Reply with quote
Sorted the fuel control via the WUR with a rpm controlled solenoid switch - http://www.924board.org/viewtopic.php?p=382472#382472
Enjoying the car in the grounds of a Welsh castle
PostPosted: Mon Jul 18, 2016 11:35 pm    Post subject: Reply with quote
Your car pics are like a high res time warp...simply awesome
1979 924 NA M471/M481 / ohne M650 Herausnehmbares Dach
0.5 1982 931 smashed parts car
1982 931 parts car?
1982 931 WB wana-be GTR race car
PostPosted: Sun Nov 06, 2016 9:37 am    Post subject: Reply with quote
Swapped out the gearboxes in the past week. Pulled this Quaife LSD from my current box for checking over before going into a replacement gearbox along with fresh syncros.
It's nice to have a box in the car again with a useable first. What's not so nice is the lack of traction when one wheel spins up all too easily with the current open diff. Can't wait to get the LSD back in asap.
PostPosted: Thu Dec 29, 2016 12:59 am    Post subject: Reply with quote
Seven years of ownership ticked off pre xmas. Had the removable badge panel off for a quick fettle and clean up to keep on top of maintenance. All's well after a leaky hose on the IC was nipped up.
Binned off the suede Momo and gearshift. Loving the Raid turbo wheel, leather gear gaiter and pure green Euro speedo. I need to get a spare mph dial white numbers coloured green asap. All feels more period 1980.
New years tasks are refit the Quaife LSD with fresh 1st & 2nd syncros in the currently fitted gearbox. A couple of paint issues to deal with. Get it on track more often than this past year. Maybe a turbo refresh with bigger compressor
PostPosted: Thu Dec 29, 2016 3:34 am    Post subject: Reply with quote
what's the light between speedo and temp?
  • Wei▀e Schei▀e (1987 924S) - In Progress
PostPosted: Thu Dec 29, 2016 3:42 am    Post subject: Reply with quote
Top right of main dials? Main beam light.
CÚdric
PostPosted: Thu Dec 29, 2016 4:41 am    Post subject: Reply with quote
Nice work, the green dials are cool! But my cluster lighting isn't that good so visibility is horrible when it's dark outside, but cool goes first
I thought that lamp was for early cars only, my cars have it inside the cluster.
┤80 924 Turbo
PostPosted: Thu Dec 29, 2016 7:04 am    Post subject: Reply with quote
love your 931!
937 DITC
PostPosted: Sat Jan 14, 2017 5:56 am    Post subject: Reply with quote
Hi Cedric
I bought a gearbox with the Quaife already installed so I have no experience of the shimming required. It has now been removed from this old box and will be installed into a new box in the coming couple of months. So will have some experience once its done
When I installed the geabox with the the Quaife I was running a little less power, circa 200 v's 225+bhp. So I was slightly disappointed to not notice any difference from the open diff. Only thing I noticed was when being a hooligan and drifting out of corners it appeared more controllable and more grip pushing the car forward as well as allowing some sideways slide.
Now running a little more power I have noticed a huge difference going back to the open diff more so. It is always spinning up a wheel on boost whether cornering or in a straight line. So cannot wait to get the LSD back in. It also lacks that punch forwards when it starts to spin a wheel in a drift.
The best part about the ATB diff is that it should less intrusive than the plate LSD's. I can say this is the case. Its also fit and forget v's the plates which need servicing. So this may be the reason in not noticing the LSD once installed, but noticing its loss when removed.
I hope that helps
Steve
kghaas
PostPosted: Mon May 08, 2017 6:38 am    Post subject: Reply with quote
Just read the whole thread.
Fantastic car!
Knut
931 RMCH
PostPosted: Mon May 08, 2017 8:22 pm    Post subject: Reply with quote
Fantastic car!
.....Thanks
Quick update. On fueling, this thread and its links are worth noting - http://www.924board.org/viewtopic.php?t=42373 . I think this mod was well worth the effort. Plugs are running far nicer colour being colder and more lean fueling on the most part. Still a touch rich over 4800rpm but don't spend too much time up there on the road.
Weekend chassis and tyre refresh. New Toyo R888R's fitted. With some homework I had hoped to fit 205 50 16 R888R's as the websites suggested the measurements were close. In reality the 205's were way bigger than the ZZR 195 50 16. Looked too big on the rim, rubbed the rear unless I removed the 20mm spacer, the front poked out too far. So I went to 195 50 16 R888R's, which are slightly smaller than the same 'size' ZZR.
Prefer the look of the ZZR over the R888R's. Has a rounder sidewall than the R888R's. Look shouldn't play a part but they will be similar performance I'm sure for what I need.
CÚdric
PostPosted: Mon May 08, 2017 10:17 pm    Post subject: Reply with quote
Interesting, seems to be similar to the old R888 then sizing wise. the old 205 15" R888 was close to 225mm wide in reality, the 205 15" pilot sport cups were closer to 205mm wide, which made a huge different with the fitting(I also like the more vintage non squared look ). The 205R888 wasnt at all a nice tyre, with the speed im doing they melted and got quite slimey with weak sidewalls, and wore down very quickly. The MPSC was way better. But I heard good stuff regarding the new Rs, will be interesting to hear how you like them after you tried them on track.
┤80 924 Turbo
PostPosted: Sun Feb 18, 2018 11:40 pm    Post subject: Reply with quote
Messing around with a lamp pod! Work in progress......
Also looking at fitting a GTS spec 2670 compressor wheel. Here is it next to a Series 1 2470, which we know is not a great wheel. Can clearly be seen why here.....
kghaas
PostPosted: Mon Feb 19, 2018 4:30 am    Post subject: Reply with quote
Love that car...
Since I cant post pics here I have started a thread on Rennlist.
Have a look and you can se my DIY lamp pod
https://rennlist.com/forums/924-931-944-951-968-forum/1051010-931-rally-monte-carlo-historique-tlc-thread.html#post14810480
Knut
931 RMCH
Page 29 of 31
