Finally....the '82 rolls
Goto page Previous  1, 2
PostPosted: Fri Dec 30, 2016 5:41 am    Post subject: Reply with quote
I need to add updated pics of new heat exchanger. . .I'll put it on my todo list.
PostPosted: Sat Sep 30, 2017 12:23 am    Post subject: Reply with quote
Updates:
Intercooler install
http://www.924board.org/viewtopic.php?p=391256#391256
...And an update that I hope helps people. Fuel pump ran continuously as well as frequency valve. Pulled relay from my S1 and that problem disappeared. Easy enough.
Then after an hour of sitting in a parking lot, near my house thankfully, car failed to start. No fuel pump this time. Once at my house (second time I am pushing this car this week) I swapped in another fuel pump relay. Still no pump. Since I have a pigtail from boost switch, due to its new location on the intercooler, I allowed the connection to touch ground...pump back in action and it fired right up
0.5 1982 931 smashed parts car
1982 931 parts car?
PostPosted: Mon Feb 05, 2018 2:51 am    Post subject: Reply with quote
Need to put an update I missed here... Fully refurbed with grease fittings added for the poly bushings.
1982 931 parts car?
PostPosted: Thu Jan 10, 2019 6:38 am    Post subject: Reply with quote
Trial fitting the billet turbo mount
http://www.924board.org/viewtopic.php?t=40910&postdays=0&postorder=asc&start=75
Like a glove
Found some oil in the intake though so rebuilding the turbo before all this is permanent. Plus a few things need to go out for ceramic coating
1982 931 parts car?
Page 2 of 2
