kghaas
Posted: Sun Feb 04, 2018 7:34 am Post subject: Help: Need a couple of measurements on 931 |
I ned two measurements:
1. The length of the exhaust tip:
How long is the exhaust tip: Measured from the end of the silencer to the tip. I have a good Box, but the tip has been cut off. I will just weld one back on.
2. The car is fitted with a 924 front lower panel without the 9 vents on each side. My plan is to just drill and cut similar pattern in the panel. It will not be Perfect, but I might weld in some reinforcements. I need to know how wide and tall are the holes.
Any tips welcome  _________________ Knut
931 RMCH |
