snakoil
Posted: Mon Jan 15, 2018 11:15 pm Post subject: how to put door card back properly |
Hi Guys, it's not the first time I remove and reinstall my door cards and usually this is a 1 minute job.
However recently I noticed for the first time the metal brackets attached to the middle door puller portion of the door.
I believe this metal bracket is intended to fit in the hole in the metal door to provide strenght when you pull the door instead of having the door card itself absorb that pull.
I'm trying to get the bracket in the hole while reinstalling the card but can't get it in.
Do you guys have any inofrmation on how to achieve this part properly? _________________ 1979 924 NA |
Posted: Mon Jan 15, 2018 11:43 pm Post subject: Re: how to put door card back properly |
snakoil wrote: | I believe this metal bracket is intended to fit in the hole in the metal door to provide strenght when you pull the door instead of having the door card itself absorb that pull. |
Correct
I don't recall having problem with that part of the process. I usually put the card against the door a bit higher than it suppose to and slide down. _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
snakoil
Posted: Tue Jan 16, 2018 5:00 am Post subject: |
Does someone have closeup picture of the bracket or measurements?
I just a saw a picture on google of a door card and I think my bracket is broken and missing a portion that would go in the hole!!! _________________ 1979 924 NA |
snakoil
Posted: Tue Jan 16, 2018 11:34 am Post subject: |
After looking at different pictures I found out the PO had flat bented the bracket.
A little love with the hammer and bench put a better angle in the bracket and got it in correctly on the first try!
Thanks for your help fellas, sometimes just writting it down allows you to think clearer. _________________ 1979 924 NA |
