Haed gasket
toast54
PostPosted: Thu Oct 26, 2017 10:55 pm    Post subject: Haed gasket Reply with quote
Well, after all I've done to get this 924S running, it seems I have a leaking head gasket..in a perfect world I would replace it, but it's not feasible at this time. I don't have coolant in my oil or oil in my coolant and it isn't overheating nor is there any gas bubbling in my coolant reservoir. I've pulled plugs and #1&#4 are definitely "steam cleaned". My question is, would there be a head gasket sealant that might possibly work? Any input would be appreciated. I am going to run cylinder compression and coolant system pressure tests this weekend
toast54
PostPosted: Sat Nov 11, 2017 5:53 am    Post subject: Reply with quote
Not a head gasket, fortunately. There are some theories being bandied about. Water in gas tank is the prevailing one
PostPosted: Sat Nov 11, 2017 11:03 am    Post subject: Reply with quote
If your only conditions are white plugs, perhaps you could suspect your injectors or fuel distributor. Water would be equally distributed (pun intended).
1979 924 NA race car
1982 924 Turbo almost a PoS
toast54
PostPosted: Fri Nov 17, 2017 12:00 am    Post subject: Reply with quote
Seems to be sorted out. There's a very small amount of smoke from the tailpipe but nothing like before. I still plan on sending the injectors to Witchhunter performance this winter. With any luck I can also work on other things I had planned for the "offseason"
