Heater blower motor
Eric P
PostPosted: Wed Nov 15, 2017 1:03 am    Post subject: Heater blower motor Reply with quote
Well, I just completed my 1500 mile trip to Iowa and back this weekend. Overall it went smoothly, and I only had one issue.
The heater fan motor died about 300 miles in. I have power to the motor, but it's difficult to spin by hand. I'm assuming by the noise it made that the brushes finally gave out.
I'm trying to find photos showing the removal of an early (1980) style blower. Most of the photos I've found are broken photobucket photos. I've gathered that I have to remove the dash or at least the console to get at the motor, but I'd love to see some photos if anyone has them.
Are there any other solutions besides pulling the dash and rebuilding the old armature? The stock fan has always seemed really weak, so I'd like to upgrade it if I have to go through all that trouble anyway. It would be even better if I could upgrade it and replace everything from under the hood.
1980 924 NA, US model
1987 924S, US model
CÚdric
PostPosted: Wed Nov 15, 2017 1:51 am    Post subject: Reply with quote
It is possible to get it from above, but that includes cutting the plastic holding the fan and gluing it back with some reinforcements. I did it that way since i didn't have time or wanted to pull the dash then. It works perfectly. I have pics if you can't find any other ones. I got the inspiration from another board member who did it in a similar way.
┤79 924
http://www.garaget.org/show.php?car=211
┤80 924 Turbo
Eric P
PostPosted: Wed Nov 15, 2017 2:48 am    Post subject: Reply with quote
If you would be able to post pictures of what you did, I would really appreciate it! I found a few threads where people retrofitted another fan, but it's almost impossible to tell what they did or how they did it without photos.
1987 924S, US model
PostPosted: Sat Nov 18, 2017 12:40 am    Post subject: Reply with quote
I put a VW Rabbit motor in and could also send pics, but it got pretty ugly to do as getting the case back together was a real cluge job. I have a fan motor(vertical) that spins from my take-a-part car that spins, but no guarantees other than that that you would be welcome to for cost of shipping, but I'm traveling until Nov 25.
Mike
'77 924
cricketdesigns.com
Eric P
PostPosted: Thu Jan 18, 2018 7:09 am    Post subject: Reply with quote
I'm planning on tearing into this weekend. If anyone has pictures of your blower motor fix, please post them. I found a handful of threads on the topic, but all pictures are dead.
I have a couple ideas, but I need to take some measurements before I decide what direction to go and order parts. I'd like to make it easy to swap the fan from above, but I may end up pulling the dash eventually to put it back to the factory configuration.
1987 924S, US model
