Aplaja
Posted: Sat Nov 04, 2017 3:37 am Post subject: Fuel rail for Megasquirt conversion |
I have '83 Porsche 924 NA and I'm making EFI conversion. I already have injectors which are from Audi TT but now I need fuel rail for them. I have searched a long time now a fuel rail that would fit in. I have told that injector center to center spacing in 924 is 95mm or 96mm but I haven't found any rail which have this spacing and a return line. I read from internet that Zetec engine fuel rail would fit but which of them?
Sorry for bad english. |
Ozzie
Posted: Sat Nov 04, 2017 6:46 am Post subject: |
I used a FORD FIESTA MK6/7 2.0 DURATEC ST150 FUEL RAIL _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
3forall
Posted: Sat Nov 04, 2017 9:52 am Post subject: |
The ford zetec one will fit but does not have a return line. I used one from a Chrysler Lebaron Turbo, the spacing is correct, it has a return line and an integrated Bosch fuel pressure regulator. They are rare but can be found on early Chrysler/Dodge k-series turbo engines. _________________ 1981 924 Weissach edition
1982 931 - Megasquirt and liquid intercooler
1969 911 |
Raceboy
Posted: Sat Nov 04, 2017 4:32 pm Post subject: |
It is possible to TIG weld a return line to the fuel rail. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Aplaja
Posted: Sun Nov 12, 2017 3:29 am Post subject: |
Can somebody send me a picture of the zetec fuel rail that fits. There are several zetec fuel rails and all of them doesn't fit. |
Ozzie
Britain
Joined: 26 Nov 2013 Posts: 285 Location: Cornelius, OR
Posted: Tue Dec 05, 2017 10:08 am Post subject: |
I am selling my EFI set-up in the classified.
Here is what I did for the fuel rail set-up for Std Bosch Injectors.
I made a custom Fuel rail and mounts. Then I machined transmission drail plugs for injector bungs that screw into the CIS ports.
Britain
Posted: Tue Dec 05, 2017 10:09 am Post subject: |
I also made a mount for a trigger wheel that uses an off-the-shelf Chevy sensor and machined an S2 intake manifold for a Subaru throttle body so I can get a TPS sensor. I also machined the fitting on the back of the head for a CLT sensor. |
Raceboy
Posted: Sat Dec 09, 2017 8:57 am Post subject: |
You can buy a direct replacement CLT temp sensor that fits in place of thermo switch. Cost is like 6 euros or so. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Ozzie
Posted: Mon Dec 18, 2017 12:09 pm Post subject: |
I did but had to get an adaptor to fit _________________ Porsche 924 1984 (UK import) NA
theclassicera
Posted: Thu Feb 01, 2018 6:52 pm Post subject: Fuel rail |
If you go on www.trigger-wheels.com they can supply a blank fuel rail and crank sensor.
Be careful on the hole centres, my head has measured at 93mm but between 3 & 4 cylinder its 95mm. But the I have been using a CMM Faro arm to measure which is uber accurate!
I have made an adaptor to take a 944 throttle body with Bosch TPS[/img] |
Posted: Thu Feb 01, 2018 11:48 pm Post subject: Re: Fuel rail |
Thanks for posting this link. Very good prices.
About 300-350 eur can set you up for EFI conversion, the rest would be wiring and ECU.
theclassicera wrote: | If you go on www.trigger-wheels.com they can supply a blank fuel rail and crank sensor.
_________________ https://www.the924.com |
Posted: Fri Feb 02, 2018 11:30 pm Post subject: Re: Fuel rail |
theclassicera wrote: | Be careful on the hole centres, my head has measured at 93mm but between 3 & 4 cylinder its 95mm. But the I have been using a CMM Faro arm to measure which is uber accurate |
Where / how are you measuring centres?
Perhaps measure again.
Any tool is only as accurate as it`s operator, indexing/ calibration or the faces / locations measured.
FYI, unless you have an uber rare head, cylinder bore, head / valve/ injector C2C spacing is 95mm between 1-2-3-4. _________________ World`s quickest 924 2L slushbox
Allan @ DTA wrote: | I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards |
CorsePerVita
Joined: 25 Jul 2008 Posts: 1992 Location: Redmond, Oregon
Posted: Thu Feb 22, 2018 6:44 am Post subject: |
Honda accord 1993/1994 fuel rails and injectors are a direct fit and require nothing more than fabricating a bracket to hold it in place. I'll snag pics when I get home. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
gegge
Posted: Thu Feb 22, 2018 9:09 pm Post subject: |
Honda F22, K20 and H22 are all 94mm. Ford Duratec and Mazda L are 96mm IIRC. Think the smaller Zetec heritaged the CVH bore spacing of 92mm? _________________ Carl Fredrik Torkildsen
