Fuel rail for Megasquirt conversion
Aplaja
PostPosted: Sat Nov 04, 2017 4:37 am    Post subject: Fuel rail for Megasquirt conversion Reply with quote
I have '83 Porsche 924 NA and I'm making EFI conversion. I already have injectors which are from Audi TT but now I need fuel rail for them. I have searched a long time now a fuel rail that would fit in. I have told that injector center to center spacing in 924 is 95mm or 96mm but I haven't found any rail which have this spacing and a return line. I read from internet that Zetec engine fuel rail would fit but which of them?
Sorry for bad english.
Ozzie
PostPosted: Sat Nov 04, 2017 7:46 am    Post subject: Reply with quote
I used a FORD FIESTA MK6/7 2.0 DURATEC ST150 FUEL RAIL
Its AUTO and its BLACK
Montego Black on black/red
3forall
PostPosted: Sat Nov 04, 2017 10:52 am    Post subject: Reply with quote
The ford zetec one will fit but does not have a return line. I used one from a Chrysler Lebaron Turbo, the spacing is correct, it has a return line and an integrated Bosch fuel pressure regulator. They are rare but can be found on early Chrysler/Dodge k-series turbo engines.
1981 924 Weissach edition
1982 931 - Megasquirt and liquid intercooler
1969 911
Raceboy
PostPosted: Sat Nov 04, 2017 5:32 pm    Post subject: Reply with quote
It is possible to TIG weld a return line to the fuel rail.
'83 924 2.5 16v Turbo, 470hp
'67 911 Irish Green hotrod, 2.4S
'89 944 S2
'91 944 S2
'78 924
'78 911 SC 2.5 ss Turbo "Martini"
'82 924S/931 "Gulf" racecar, 330 hp, sold
'84 924, turbocharged, sold.
Aplaja
PostPosted: Sun Nov 12, 2017 4:29 am    Post subject: Reply with quote
Can somebody send me a picture of the zetec fuel rail that fits. There are several zetec fuel rails and all of them doesn't fit.
Ozzie
PostPosted: Mon Nov 13, 2017 11:37 am    Post subject: Reply with quote
https://www.ebay.com.au/itm/NEW-Ford-Focus-Mondeo-ST150-Galaxy-S-Max-2-0-Duratec-Fuel-Rail-Injectors/362137661899?hash=item54511631cb:g:qoYAAOSwopRYcojx
should fit, could tig a return line if needed.
Britain
PostPosted: Tue Dec 05, 2017 11:08 am    Post subject: Reply with quote
I am selling my EFI set-up in the classified.
Here is what I did for the fuel rail set-up for Std Bosch Injectors.
I made a custom Fuel rail and mounts. Then I machined transmission drail plugs for injector bungs that screw into the CIS ports.
Britain
PostPosted: Tue Dec 05, 2017 11:09 am    Post subject: Reply with quote
I also made a mount for a trigger wheel that uses an off-the-shelf Chevy sensor and machined an S2 intake manifold for a Subaru throttle body so I can get a TPS sensor. I also machined the fitting on the back of the head for a CLT sensor.
Raceboy
PostPosted: Sat Dec 09, 2017 9:57 am    Post subject: Reply with quote
You can buy a direct replacement CLT temp sensor that fits in place of thermo switch. Cost is like 6 euros or so.
'89 944 S2
'91 944 S2
'78 924
Ozzie
PostPosted: Mon Dec 18, 2017 1:09 pm    Post subject: Reply with quote
I did but had to get an adaptor to fit
theclassicera
PostPosted: Thu Feb 01, 2018 7:52 pm    Post subject: Fuel rail Reply with quote
If you go on www.trigger-wheels.com they can supply a blank fuel rail and crank sensor.
Be careful on the hole centres, my head has measured at 93mm but between 3 & 4 cylinder its 95mm. But the I have been using a CMM Faro arm to measure which is uber accurate!
I have made an adaptor to take a 944 throttle body with Bosch TPS[/img]
PostPosted: Fri Feb 02, 2018 12:48 am    Post subject: Re: Fuel rail Reply with quote
Thanks for posting this link. Very good prices.
About 300-350 eur can set you up for EFI conversion, the rest would be wiring and ECU.
red 924 and not red 924
PostPosted: Sat Feb 03, 2018 12:30 am    Post subject: Re: Fuel rail Reply with quote
Where / how are you measuring centres?
Perhaps measure again.
Any tool is only as accurate as it`s operator, indexing/ calibration or the faces / locations measured.
FYI, unless you have an uber rare head, cylinder bore, head / valve/ injector C2C spacing is 95mm between 1-2-3-4.
Allan @ DTA wrote:
CorsePerVita
PostPosted: Thu Feb 22, 2018 7:44 am    Post subject: Reply with quote
Honda accord 1993/1994 fuel rails and injectors are a direct fit and require nothing more than fabricating a bracket to hold it in place. I'll snag pics when I get home.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
gegge
PostPosted: Thu Feb 22, 2018 10:09 pm    Post subject: Reply with quote
Honda F22, K20 and H22 are all 94mm. Ford Duratec and Mazda L are 96mm IIRC. Think the smaller Zetec heritaged the CVH bore spacing of 92mm?
Carl Fredrik Torkildsen
