bufflars12
Posted: Mon May 01, 2006 1:36 am Post subject: |
thanks man |
vintageant
Joined: 15 Apr 2016 Posts: 35 Location: Miami, Florida
Posted: Tue Oct 24, 2017 3:55 am Post subject: Radiator fans - how to replace |
Is there anywhere on this site a "How to" replace the radiator fans? Driver's side fan is seized. Suspect bearing.
Thanks! _________________ New first time 1987 924S owner - April 2016
1970 VW 'Peking to Paris Rally' Beetle |
pmcaya2
Joined: 24 Nov 2005 Posts: 183 Location: Scio, NY USA
Posted: Tue Oct 24, 2017 2:07 pm Post subject: |
I replaced one of my fans with a generic fan from Amazon. I mounted it in the existing cowling. Had to set polarity so it would pull through the radiator. I have a bad thermo switch on the radiator but was concerned that I'd damage the radiator if I changed it. I learned that if you have AC, if you turn the fan to 1 both fans will run continuously. No separate switch needed.
I can check the specs on the fan I bought if you'd like. Good luck - Peter |
vintageant
Posted: Wed Oct 25, 2017 5:43 am Post subject: |
Thanks Peter!
Yes, if you can dig out those Amazon fan specs, I'd be very grateful!
A new gen-u-wine Porsche fan is about $485!
John _________________ New first time 1987 924S owner - April 2016
pmcaya2
Posted: Wed Oct 25, 2017 9:24 am Post subject: |
I remembered that it's a 10in fan and I mounted it inside the shroud with some modification to the outside of the fan. Spliced wires into existing connection taking care to have polarity so it pulls air through the radiator. The old fan looks like it was built for a Panzer tank! This is much lighter but seems to put out a good air flow. There were absolutely no directions, but it had a high rating at amazon - and low cost. Good luck - Peter
https://www.amazon.com/gp/product/B00T3TK3EW/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 |
vintageant
Posted: Sat Nov 04, 2017 12:24 am Post subject: |
Thanks again Peter!
I ordered that fan and initially thought it would not fit into the fan shroud, but with some judicial trimming with my Dremel got it to fit. Obviously it doesn't fit where the three nuts hold the original fan, but the cable ties secure it nicely. I had a 50/50 chance with the polarity and got it right the first try! At $25.95 delivered certainly a better deal than the $485 ++ Porsche part!
Haven't yet been out on a long drive, but all appears to work as it should!
Great guidance!
PS: This video was very helpful https://www.youtube.com/watch?v=SDXeuXzhUqY&vl=en _________________ New first time 1987 924S owner - April 2016
pmcaya2
Posted: Sat Nov 04, 2017 9:24 am Post subject: |
John - Glad that the fan worked for you - I didn't want to go with a smaller fan. Some shade tree mechanic mods puts it in the housing nicely. As I said I run both fans full time by turning the AC on. Good driving - Peter |
