Johnparmenter82
Joined: 11 Sep 2016 Posts: 12 Location: Rochester, new york
Posted: Sat Oct 28, 2017 9:32 am Post subject: Won't start, coming off engine rebuild |
Getting power but won't turnover, no clicking, no nothing. I'm getting power and lights and tried my battery pack but still nothing. _________________ Johnparmenter82 |
Ian89C4
Posted: Sat Oct 28, 2017 11:35 pm Post subject: |
Did you give the solenoid on starter a tap with a hammer? Sometimes sitting that long, if not replaced, they can just get a little stuck.
Does the engine turn by hand?
Once she turns on her own with the starter, if still no start, then start the air, fuel, spark trouble shooting that we all love.
Good luck.
Cheers _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Posted: Sun Oct 29, 2017 3:47 am Post subject: |
Make sure you have installed the engine ground wire from the coil area to the block properly. _________________ White 87 924S "Ghost"
Posted: Sun Oct 29, 2017 5:07 am Post subject: |
Are the 16 and 50 wires connecting to the starter solenoid reversed? If so get nothing. _________________ Mike
'67 MG Midget Dp
sciroccosteve
Joined: 16 Apr 2012 Posts: 215 Location: Rochester, NY
Posted: Sun Oct 29, 2017 6:36 am Post subject: |
I helped with the rebuild, some things still not attached, I didn’t think that ground from coil bracket to block would be an issue? _________________ 1979 924
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns |
Posted: Sun Oct 29, 2017 8:25 am Post subject: |
Absolutely will cause the issue. On NA cars I've seen the clutch cable melt and snap when trying to start the motor with this ground disconnected. _________________ White 87 924S "Ghost"
