931 Clutch Disc alternate
Golten951
PostPosted: Sat Oct 21, 2017 5:51 pm    Post subject: 931 Clutch Disc alternate Reply with quote
Hey friends,
Just a neat tip of info I found out. The 1990s Ford Ranger 2.3L uses the same basic clutch disc as the 931. can be had for $30 to $50 from rockauto or ebay. Clutch size is US 8 7/8" 1" spline with 23T. Metric 225MM 25MM spline with 23T. the 931 uses the same throw out bearing as the 944 NA. I hope this helps someone out.
PostPosted: Sat Oct 21, 2017 10:49 pm    Post subject: Reply with quote
Makes sense; we used possibly the same clutch to fit the torque tube and gearbox from the 944 into the 924 NA to give an inexpensive 5-speed upgrade, when the proper 924 gearbox wasn't available...
'79 924 #77 ITB racecar
Golten951
PostPosted: Sun Oct 22, 2017 8:32 am    Post subject: Reply with quote
Most certainly, It is pretty neat what other parts are interchangeable. like the Mazda RX8 Clutch disc can be used for the 944 Turbo. and the Mitsubishi 3.0l Eclipse solid disc (still undergoing research) should be able to be used in the 944NA.
kghaas
PostPosted: Thu Nov 02, 2017 6:42 am    Post subject: Reply with quote
Nice info. Do you have a link or product number?
Knut
931 RMCH
Golten951
PostPosted: Sun Nov 12, 2017 4:21 pm    Post subject: Reply with quote
Check out Rockauto.com 1991 Ford Ranger 2.3L L4 M-PACT 381041D 8-7/8' X 1' X 23T will fit the 931 perfectly. $37 to $40 depending on shipping location.
