Random Parts Lot
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale
Kenodog
PostPosted: Thu Oct 19, 2017 7:50 am    Post subject: Random Parts Lot Reply with quote
I came across a local old timey Porsche shop here that has changed owners. The new owner is clearing off the shelves of old stock to make way for 911 stuff. Some of the parts I will use but this stuff is left for 924 N/A cars, 944 / 951. They offered me a lot price but since less than half of it I can use I want to see if anyone here has use for the rest. If you do please let me know asap so I can let them know about the sale. All parts are NOS.
944-106-249-01 overflow tank hose 924S, 944, 944S
477-398-001 AT gasket set (no filter but has pan gsket)
803-721-335-A clutch cable 924 76-79
477-998-031 ign wire set, Karyln
047-105-169-A pilot bearing, 924 76-85, x2
N-900-190-01 rear muffler clamp (approx 6in across, 1 bolt, yellow cad plated) >79, OE Porsche
477-253-253 muffler bracket >79, OE Porsche
477-253-115-E muffler gasket, manifold to downpipe 76-85
113-141-165-B release bearing, Sachs
931-302-301-02 syncro ring (1st gear I believe) OEM
059-198-451 main bearing set x2, Kolbenschmidt 76-79 (60mm cranks)
477-611-017-A brake master cyl, ATE 80-85, Turbo from 81
046-109-675-A valve stem seals x9
944 PARTS:
951-106-241-01 upper rad hose, 944 85-91 OE Porsche
944-572-479-00 Cabin Pollen Filter, 968
944-102-051-00 flywheel 83-early 85
944-102-051-01 flywheel, 944 (late 1985-8, 924S, Turbo
951-332-901-00 CV joint kit, 944/S/S2 (1987-1991) (944S2/TURBO)
968 (1992-1995)
Leigh
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kid's limo)
2008 GS500
1996 Dodge Caravan (DJV)
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale All times are GMT + 11 Hours
