Posted: Fri Sep 29, 2017 5:19 am Post subject: |
The vacuum line feeding the blow off on my GTS wannabe is small in diameter and sometimes the blow off does not open...the push is very violent and I don't like it...also because of the CIS in front of the turbo there is no noise. _________________ https://www.the924.com |
Posted: Sun Oct 01, 2017 2:18 am Post subject: |
morghen wrote: | ...the push is very violent and I don't like it... |
Thanks for that piece of info, close system is definitely not for me then. _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
Posted: Sun Oct 01, 2017 2:59 am Post subject: |
Ok but remember i run 1.1bar on a k27...thats more air by a fair amount compared to the factory k26. So for the factory setup it may be a little smoother? Dont know..but what i know is that i love the open blow off sound when shifting gears. _________________ https://www.the924.com |
Posted: Fri Oct 06, 2017 12:41 am Post subject: |
I purchase the seats kit from Only944.com
All was good, delivery time, packaging, all required hardware and product quality.
Online instruction are good, lots of pictures and explanation.
Two things to mention:
1-The online instruction is only for the regular 944 seat and does not cover the difference/particularity of the sport seat.
2-Although 924 and 944 seats are interchangeable, they are not the same. Few little things are different.
Overall, not to hard to figure out how to adapt to sport seats and to adapt for earlier seats.
It took me a total of 7 hours to do both seats spread over a week. About 4 hours for the first one and 3 hours for the second.
I'm happy with the result and can't wait to install and enjoy them.
Before
After
1980 931S
Posted: Fri Oct 06, 2017 12:49 am Post subject: |
happy first wet fart in new seats to you ! _________________ https://www.the924.com |
Posted: Fri Oct 06, 2017 12:55 am Post subject: |
1980 931S
Posted: Fri Oct 06, 2017 2:53 am Post subject: |
UPDATED
Here's some detail on the build:
Suspension
-new Bilstein HD all around
-sway bar 23mm front, 16mm rear with KLA drop link
-poly bushing on sway bar, torsion bar, front and rear arms
-solid bushing on torsion bar carrier mounting point
-solid KLA top strut
Clutch
-915 pressure plate, rebuild clutch and resurface flywheel
-new poly shifter bushings and short shifter
-new clutch master and slave cylinder
Interior
-GTS replica rear portion roll bar
-Manual sport seats
-Dual gauge pod (speaker grill delete center dash)
-Wideband analog AEM O2 and gauge
-Dual air intake temperature gauge (pre and post IC)
-Delete driver and passenger sound reducer mate
-Delete driver and passenger carpet and replaced with EZ cool and lightweight carpet
-Delete rear seat top and bottom
-Delete rear sound reducing mate
-Delete rear carpet
-Delete spare tire and jack
-Delete radio and speakers
-Delete rear ¼ inside panel
-Remove sunroof inside panel
-Cut bottom part of center console (GTS style)
Engine bay
-935/924 GTR in cabin manual boost controller
-Front mounted inter-cooler with 2.25in piping
-GTS intake manifold
-3 layer Cometic head gasket
-APR head bolts
-ceramic coated S2 exhaust manifold, J pipe and wastegate dump pipe
-high torque starter
-high output alternator
-944 coolant reservoir
-Lindsey Racing silicon vacuum hose kit (5/32 inch)
-Delete A/C
-Lightweight battery (12lbs)
Body
-new weather strips (hatch, hatch lock, sunroof, door, window scraper and ¼ window)
-944 rear spoiler
-AIR fibreglass GTS front bumper, rear flare, hood scoop and rocker panel
-944 front fenders
-euro rear bumper
-944 script door handle
-GTS style flush mounted windshield
-GTS headlight kit
-Fibreglass hood
-Plexiglass rear hatch
-Manual mirrors
-Manual windows
Brake and Wheels
-Front and rear SS braided brake line
-951 fuchs, 7x16 with 205 and 8x16 with 225
And I probably forgot few more things
Weight reduction of around 300lbs
Next on my list:
-Strut brace (sitting in my garage)
-Adjustable cam gear...maybe...
-Early S1 turbo with the 6.10 hotside
I'm currently running 15lbs of boost and the FMIC has no problem keeping the intake air temperature at around 10°F above ambient temperature, which is better/lower temperature than the stock setup (no IC and 6lbs of boost). _________________ 1976 924 N/A ROW SOLD
1980 931S
jacobroufa
Posted: Fri Oct 06, 2017 3:31 am Post subject: |
Good lookin' seats!!! I'd love a pair of sport seats one day... |
Posted: Fri Oct 06, 2017 8:59 am Post subject: |
I could not wait any longer
1980 931S
Posted: Fri Oct 06, 2017 6:23 pm Post subject: |
I'd recommend re installing the carpets and trim into the rear of the car. They weigh next to nothing and make the cabin feel and look nicer. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Fri Oct 06, 2017 8:32 pm Post subject: |
Carrera RSR wrote: | I'd recommend re installing the carpets and trim into the rear of the car. They weigh next to nothing and make the cabin feel and look nicer. |
I have plans to apply EZ cool and lightweight carpet over the rear seats and rear of the car. Maybe next spring. _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Fri Jun 08, 2018 8:36 pm Post subject: |
Having some fun at the track
1980 931S
Posted: Sat Jun 09, 2018 2:09 am Post subject: |
I really like the look of this style center console delete..
I might do mine like that one day..
Your car is gorgeous..
As far as the BOV..
When you (whoever) ran with no BOV, closed system, what sort of psi spikes were you seeing when you dropped the throttle?
You didn't have a problem with blowing any of the various boost/vac diaphragms on the car?
I wonder how the WG diaphragm feels about seeing a sudden 50-75 psi spike?
The thought crossed my mind to worry about the distributor diaphragms blowing due to high boost but if you didn't blow any of them running with no BOV then I guess they are G2G.. Not sure if you guys had vac/boost distributors though..
You have probably scene the BOV I run. It's a china one but seems to work.. Might be a bit too small..
I had it hooked to the wrong vacuum (ported) for a while and it made my engine rev in between shifts and lag from wot to off throttle..
Another idea for you..
If you want to experiment with the fitment of a "upgrade" turbo, you can put a standard (no built in recirc valve) compressor housing on your 2664.. A compressor housing that looks and fits just like the 951 ones..
Then you could build all of your piping and get your aftermarket BOV installed and working, get the package ready..
That way you don't have to bite the $$ for the turbo upgrade, bite the turbo swap job, and bite the custom intake stuff all at the same time..
This way at first you can bite just the custom intake project to make it work and you will be ready to "drop in" a 951 compressor..
You can swap the compressor housings with the turbo fully installed in the car thereby eliminating the wretched job of swapping the entire turbo on these cars...
You can do this very cheap too because I will loan you the standard 2664 compressor housing if you want..
The biggest pain here is making and installing a new boot from the comp to the AFM including a 1" line off of the boot for your BOV recirc to blow back into..
Mine is, from comp to AFM, 2.5"-3" reducer 90 to 3" coupler with a 1" NPT bung to about a 45 3" to the AFM, but use a 90 and cut it in the middle of the bend for that one..
This is the most difficult part of my piping to make and get all the angles right, very difficult to install up in there also..
Pretty much get it right once and NEVER take it apart again, just take it off by the ends and it will stay right.. _________________ 80 Turbo - Slightly Modified
Last edited by Fasteddie313 on Sat Jun 09, 2018 2:45 am; edited 2 times in total |
Posted: Sat Jun 09, 2018 2:21 am Post subject: |
Ref the BOV, I'm still running the EOM re-circulation valve on mine, so I can't answer your questions. _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Sat Jun 09, 2018 7:49 am Post subject: |
I ran my turbo with the recirc valve closed and no BOV. No boost spikes according to my datalogger. I hopefully have a new turbo on its way later this summer. It won’t have a recirc valve. Nor will it have a BOV. I do hope it has Quattro S1 style compressor surge. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
