Raceboy
Posted: Mon Oct 02, 2017 4:06 am Post subject: Found injectors with long nose suitable for EFI conversion |
Even though pretty much any injector works with 924/931 when doing an EFI conversion, the nozzle still sits in a sort of tube left from long CIS injector. That harms driveability a bit.
Since I may be converting one 924 n/a to turbo some time in the future I was looking for injector that is bigger than 200cc or so (that most long-nose injector are usually).
Bosch 0 280 158 123 is 590cc, high-impedance and good for quite a bit of power on 924
These are actually OEM injectors for 997 Turbo for example and few others.
_________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Kenodog
Joined: 25 Jun 2003 Posts: 2645 Location: Vancouver,B.C.
Posted: Mon Oct 02, 2017 5:24 am Post subject: Re: Found injectors with long nose suitable for EFI conversi |
Raceboy wrote: |
Oh good, at least they'll be cheap then..
Leg _________________ 1979 Euro 931, Olive
1981 931, Sabine
1991 Ford Ranger XLT 4x4
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Raceboy
Posted: Mon Oct 02, 2017 5:36 am Post subject: |
They are usual price, around 50-60 usd/eur for a piece new, depending where you buy. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
3forall
Posted: Mon Oct 02, 2017 9:52 am Post subject: |
An easier and cheaper alternative are those from a Volvo with the turbo 1.9. They are 42lb or about 440cc injectors with the long nose. I drilled out some injector cups (don't know what car or injectors they were meant for, but they had the right thread) and the injector sits flush with the bottom of the injector hole. I got 8 at the junkyard for 20$. I then cleaned and flow tested and all was dandy.
http://www.ebay.ca/itm/Reman-Siemens-Deka-Fuel-Injector-6900371-Volvo-1-9L-Turbo-/300975840297
Reman they go for around 40$ _________________ 1981 924 Weissach edition
1982 931 - Megasquirt and liquid intercooler
1969 911 |
gegge
Posted: Wed Oct 04, 2017 5:11 am Post subject: |
I have the big brother 040 pumping 980cc
Conical spray pattern instead of wide twin beam pattern for multivalve engines. _________________ Carl Fredrik Torkildsen
Raceboy
Posted: Wed Oct 04, 2017 5:33 am Post subject: |
Isn't 040 a CNG/LPG injector originally? Any issues? _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Posted: Sun Oct 15, 2017 5:21 am Post subject: |
gegge wrote: | I have the big brother 040 pumping 980cc
Conical spray pattern instead of wide twin beam pattern for multivalve engines. |
Part number?
Trying to gather parts for vems conversion...those 911 injectors look good and will be 200 eur new for a set...but i'm shopping _________________ https://www.the924.com |
gegge
Posted: Sun Oct 15, 2017 10:20 pm Post subject: |
E85 compatible 0 280 158 040
Didnīt know they worked with CNG and LPG _________________ Carl Fredrik Torkildsen
