Turbochargers
fwood
PostPosted: Tue Sep 26, 2017 9:13 am    Post subject: Turbochargers Reply with quote
I have a S2 931 that I have installed a rebuilt S1 turbocharger on. I have continually chased hot running problems that initially were fuel related due to dirty fuel infrastructure which I have hopefully addressed. In the Porsche FSM it says that the different chargers are not interchangeable. Is this true.
Frank
1982 931
Frank Wood
82 931
PostPosted: Tue Sep 26, 2017 3:37 pm    Post subject: Reply with quote
Does your car work?
Ruby-sh 924
fwood
PostPosted: Wed Sep 27, 2017 1:10 am    Post subject: Reply with quote
Yes. I have checked wur,Aav,fuel distributor,changed fuel pump and filter,cleaned fuel tank,all vacuum lines are good. It starts cold beautifully, idles strong,runs good until I drive for a while then it starts to starve out,with slight backfire, at which time it seems to almost overheat and die. After throughly cooling will go through the same process. I don't remember having this problem with the Original s2 turbo except when the fuel filter clogged which is clear now. I changed turbos because of an oil leak in the original and I got an s1 turbo that looked to be in better shape whichI had rebuilt.
Frank Wood
82 931
PostPosted: Wed Sep 27, 2017 1:58 am    Post subject: Reply with quote
Your problem is probably not the turbo.
They are interchangeable, meaning they will bolt on and the car will run fine.
Ruby-sh 924
PostPosted: Wed Sep 27, 2017 3:03 am    Post subject: Reply with quote
Agreed. First thing I would try is replacing the ignition module on the inner fender well. There have been a few recent reports of these causing symptoms like what you're describing when the heat sink glue dries up and disintegrates. These can be gotten new for very reasonable cost.
PostPosted: Wed Sep 27, 2017 4:24 am    Post subject: Reply with quote
I drove a s1 turbo on a s2 for a couple of years, no problem at all!
937 DITC
PostPosted: Wed Sep 27, 2017 4:55 am    Post subject: Reply with quote
Many frankenturbo’s out there and the owners are none the wiser. PRevious owners and garages have been mixing them up for nearly 40 years
fwood
PostPosted: Sun Oct 01, 2017 9:50 am    Post subject: Reply with quote
Thanks for those replies. I will try the ignition module. This is one of the best forums with absolutely priceless help.
Frak
Frank Wood
82 931
