16v head swap? lets work it out!
Goto page Previous  1, 2, 3
PostPosted: Thu Sep 07, 2017 4:37 pm    Post subject: Reply with quote
custom cams can be made, is that head cutting feasible? do the spacing and bores work? how about the stuts?
red 924 and not red 924
Paulyy
PostPosted: Mon Sep 11, 2017 6:37 pm    Post subject: Reply with quote
Im actually not sure which 20v head we're talking about. The 5 cylinder or the 4 cylinder??
I can't find info in either.
Cutting and welding a 5 cylinder head into 4? i dont think it's really feasible if everything lined it. maybe, depends on head design.
951 - 400whp.
PostPosted: Mon Sep 11, 2017 7:47 pm    Post subject: Reply with quote
I was talking about taking a 5cyl audi head and cutting it to fit the 924 if the spacing is ok and the head studs position are an advantage.
Paulyy
PostPosted: Mon Sep 11, 2017 7:54 pm    Post subject: Reply with quote
The 07K head? i dont think so. it'll require to much work to even consider it. Give it a google search to see how it looks.
951 - 400whp.
PostPosted: Mon Sep 11, 2017 8:32 pm    Post subject: Reply with quote
meh, I believe you, I was just talking out of my ass
One could CNC one I guess....or CNC a head and block in one piece and run 10bar of boost making 5000hp
Paulyy
PostPosted: Mon Sep 11, 2017 8:43 pm    Post subject: Reply with quote
hahaha!
Trust me, if i had a 5 axis, i would be drawing up a head by now.
I only have a small 3 axis cnc router.
Im looking at combustion chambers, if its worth cutting into a n/a head. even if it's 5mm deep. i did make a thread about it just before.
I know the 931 head has it, and i did see someone modify it to some extent.
951 - 400whp.
v2rocket_aka944
PostPosted: Tue Sep 12, 2017 6:50 am    Post subject: Reply with quote
not the o7K...
i meant the old 20V "AAN" 5 cylinder of the 1980s rally cars...
2.2 or 2.3L usually, found in the audi Quattro coupes, some sedans, etc.
the 924 I-4 shares a bellhousing pattern with that 5 cylinder which is how the 5 cylinder bolts up easily enough.
could the 924 engine be derived/related to the Audi 5?
or just coincidence of bolt pattern?
PostPosted: Wed Sep 13, 2017 1:09 pm    Post subject: Reply with quote
Porsche Audi and VW were the same company in years past, so they were just using what was in their supply chain.
PostPosted: Wed Sep 13, 2017 5:47 pm    Post subject: Reply with quote
v2rocket_aka944 wrote:
not the o7K...
The old Audi i5s have a much smaller bore spacing than the original 2.0
Page 3 of 3
