Ideola Liquid to Air Intercooler Install
Goto page Previous  1, 2, 3  Next
PostPosted: Fri Sep 01, 2017 11:34 pm    Post subject: Reply with quote
So the Borg Warner turbine housings are investment cast stainless...what material exactly I have not figured out yet. Thinner, lighter, smoother, crack and high temp resistant...more retained heat...
ok...this didn't take long
http://kubotametal.com/alloys/heat_resistant/HK-40.pdf (HK30-HK40)
There are others but HK30 is what the EFR hot side is based on. Can be polished too.
We could make two styles, a 3 bolt and a four
Edit: CF8C-Plus stainless seems to be a better material
Edit: just laughing to myself how the modern world of running lean and hotter to save gas has caught up to my glowing red hot manifold of my '80 931....and how my threads either die or go off on tangents. I build an engine mount and we talk about billet heads. Now an intercooler inlet pipe and we talk about new exhaust manifolds If it wasn't for google we would never be able to search our topics.
1982 931 Red Resurrection - NEW!
1982 931 parts car or resurrection?
WEASEL149
PostPosted: Sat Sep 02, 2017 1:47 am    Post subject: Reply with quote
I love threads like this, especially when the discussion goes off on a tangent .
I'm also a fan of the American way of machining/modding/hot-rodding, whatever you want to call it.
The 924 Turbo is creeping up in value in the UK and now quite rare so the current trend here is that everything has to be OEM/standard etc. From what I see it's gradually turning from an enthusiast car to an investment car. It's not really my scene I'm afraid to say.
So what I'm trying to say in a long-winded way is keep it up. By all means take a four foot cube of ally and machine it
I think I just need to move to the USA and buy me a proper pushrod V8 muscle car and have done with it. EU/UK bullshit strategies on cars are boring.
1979 UK 932
WEASEL149
PostPosted: Sat Sep 02, 2017 1:55 am    Post subject: Reply with quote
Going back to the Borg Warner investment cast turbine housings, they had problems with their earlier batches IIRC but can't remember why.
1979 UK 932
Kenodog
PostPosted: Sat Sep 02, 2017 2:07 am    Post subject: Reply with quote
I would instead just make two different exhaust manifolds. One standard eith a 3-bolt flange and one a standard T-28 / T-30 4-bolt flange. Bolt on Inconel manifold with the option to direct bolt on a new double ball bearing T-28 would be the shizzle my nizzle.
Lei
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kinderwagon)
2008 GS500
1996 Dodge Caravan (DJV)
PostPosted: Sat Sep 02, 2017 3:13 am    Post subject: Reply with quote
Lately I have been trying to build things that can be bolted on but easily (ok not normally easy ) and returned to stock if the value rises or whatever.
By changing things like the motor mount, turbo mount and so forth. I am lightening things that are not typically lightened and I can return to stock if I want.
I have the luxury of owning a few so the '79 I will likely keep closer to stock, since it seems rare to begin with, but my '80 931, a four-bolter by birth, isn't something somebody wants for big dollar in the future, at least the way I am thinking now. Not to mention its history before '89...before me. So I can play with this 931.
The '82 Turbo, that is getting this inter-cooler, is somewhat of a rescue and I am trying to keep its integrity to a point.
I hope to have an update on the part by the end of today
PostPosted: Sat Sep 02, 2017 3:17 am    Post subject: Reply with quote
Lei
At one point I wanted to machine (crazy) 3 or 4 pieces that I would then weld together. The last part having some sort of a v-band so that I could go 3 or bolt depending on the chosen turbo....I pushed this idea to the side
PostPosted: Sat Sep 02, 2017 3:45 am    Post subject: Reply with quote
To show that things do not always go smoothly, I am posting up a pic of a mid process weld up repair. There was a 'rapid' move by the endmill that should not have gone through the flange outer edge so I decided to weld it up before continuing. Not sure yet if it was my tweaking of 40K lines of code manually at the machine or a mistake from the CAM software. I'll sort that issue later....onward
PostPosted: Sat Sep 02, 2017 5:40 am    Post subject: Reply with quote
Sometimes its like watching water boil with a match but relentless just the same... I do slow it down though and turn off the coolant for the video
https://vimeo.com/232085086
Getting somewhere
PostPosted: Sat Sep 02, 2017 10:44 pm    Post subject: Reply with quote
PostPosted: Tue Sep 05, 2017 1:29 am    Post subject: Reply with quote
Updates..
Inner surface of the pipe only...see where I am going with this exercise?
PostPosted: Thu Sep 21, 2017 7:10 am    Post subject: Reply with quote
Oh you know where this is going after 92Forty1 is over...Billet Head
For now though. CNC porting the intercooler inlet pipe
https://vimeo.com/234741147
PostPosted: Thu Sep 21, 2017 9:14 am    Post subject: Reply with quote
You are really doing some awesome stuff..
This stuff is going to be amazing when you are done..
PostPosted: Thu Sep 21, 2017 11:28 pm    Post subject: Reply with quote
Thank you and I hope so
This pipe though is being rushed for Dan's event tomorrow. Would like to see more of the outside finish to be from the CNC. the next one
I saw the other video postings from 19 days ago and was amazed at how interrupted I got.
Hopefully there will be more updates today
PostPosted: Sat Sep 23, 2017 12:08 am    Post subject: Reply with quote
Big mishap yesterday but salvageable. Mishap not shown.. we are almost finished with this one at least
PostPosted: Sat Sep 23, 2017 4:55 am    Post subject: Reply with quote
Down to the wire today...looks like I am mad maxing the intercooler radiator
Page 2 of 3
