check valve vacuum 931 S2 ?
PostPosted: Fri Jul 21, 2017 3:26 pm    Post subject: check valve vacuum 931 S2 ? Reply with quote
Does a 931 S2 (ROW) have a check valve in the vacuum lines? (except for the one in the brake booster)
If yes, where should it be ?
PostPosted: Fri Jul 21, 2017 5:17 pm    Post subject: Reply with quote
As far as I know only the S1 has this.
PostPosted: Fri Jul 21, 2017 6:12 pm    Post subject: Reply with quote
Correct. Only the S1 has vacuum/retard via the distributor and the red/white check valve is required to manage the pressures.
