Posted: Thu Aug 28, 2014 3:03 am Post subject: |
I wired mine...
alternator power 1 into 2 (both fans), then fans ground to thermofan switch, then thermofan switch to alternator ground...
and it works excllent... I could prolly use an inline fuse just off of the alt power but I haven't yet...
the only good power under the hood of my car that I know of is that alternator power because my main battery power wires are now hooked up just under the starter motor..
I had to get the air filter housing out of my way a bit to get to that thermofan switch but it wasn't that difficult..
I just figured id add a successful hookup to the end of this thread for anyone who reads this down the road trying to do the same..
thanks all for the help..
edit: thermofan, not thermotime... _________________ 80 Turbo - Slightly Modified
!tom
Joined: 28 Aug 2006 Posts: 1907 Location: Victoria, BC Canada
Posted: Sat Sep 27, 2014 1:37 pm Post subject: |
Thermotime switch is intended to operate the cold start injector.
Are you sure you have described your setup accurately? _________________ 78 924 NA
5-lug |
Posted: Wed Oct 08, 2014 7:34 am Post subject: |
omg...
THERMOFAN switch.... not thermotime...
my apologies, blond moment _________________ 80 Turbo - Slightly Modified |
pmcaya2
Joined: 24 Nov 2005 Posts: 183 Location: Scio, NY USA
Posted: Tue Jul 18, 2017 12:44 pm Post subject: You already have a fan switch |
I have my fans running full-time. No switch needed ===> just turn on the AC fan and they will run! PS I know its cheap and easy to replace the thermo switch, however, cracking the radiator wasn't worth the risk for me. |
