1982 924 Turbo Timing Belt/Water pump replacement
Bryan S
PostPosted: Sun Nov 27, 2016 12:36 pm    Post subject: 1982 924 Turbo Timing Belt/Water pump replacement Reply with quote
I replaced the timing belt and water pump on a 1988 944 a few years back and followed a very detailed Youtube video that provided step-by-step instructions. Does anyone know if this process is the same for a 1982 924 Turbo? If not, are there any good videos or instructions for the timing belt replacement?
Bryan
PostPosted: Mon Nov 28, 2016 5:40 am    Post subject: Reply with quote
They are entirely different. The '82 version is dirt simple. Get a Haynes manual.
1979 924 NA race car
1982 924 Turbo almost a PoS
Edwardsgw
PostPosted: Thu Jun 29, 2017 2:28 pm    Post subject: Reply with quote
I found replacing the timing belt to be quite easy. I found getting the timing belt cover off so I could replace the belt to be quite challenging (i.e. I would rather do a 944). This forum was quite helpful. One key to allowing access to get the cover off was to unbolt the fuel distributor/metering unit assembly from its mount and disconnect the boot going to the turbo, leaving the lines all connected. This allows it to be moved far enough out of the way to just barely get the timing belt cover off.
1987 944S
1987 300TD Turbo
1987 944 track car
1988 944 Turbo S (silver rose)
1992 500E
1993 400E
1994 E320 Cabriolet
1999 996
1999 SL600
1976 Ford F350 Crew Cab
