Car holding vacuum and making boost but AFR gauge is wonky
canyonblaster
PostPosted: Sat May 13, 2017 6:47 am    Post subject: Car holding vacuum and making boost but AFR gauge is wonky Reply with quote
Guys,
My car has Dan's Intercooler kit. Love it. Car was running great, making 10 psi consistently and the boost gauge works fine. The AFR gauge WAS working fine, showing approx 14.7 at idle and around 10-11 at WOT/ on boost.
The AFR gauge is now just wonky, all over the place. Acts like it has a short but the power is constant (light doesn't flicker, etc).
Car runs fine. Boost gauge has no issues and the car doesn't drive any different. Porsche mechanic says car holds vacuum and makes boost just like it was previously.
Is it possible that the wide band Ox Sensor that feeds info to the AFR gauge went bad? Or the gauge went bad?
PCA Licensed Club Racer & Driving Instructor, Current cars: 1981 931, 2005 996 GT3, 2013 Cayenne GTS
PostPosted: Sat May 13, 2017 7:18 am    Post subject: Reply with quote
Innovate AFR sensor/gauge? Mine needed constant recalibration. Got fed up with it. Sold it. Bought a Zeitronix. Never looked back.
canyonblaster
PostPosted: Sat May 13, 2017 7:22 am    Post subject: Reply with quote
AEM analog...
PostPosted: Sat May 13, 2017 7:31 am    Post subject: Reply with quote
Some need calibrating. Sensor can go bad.
PostPosted: Sat May 13, 2017 2:49 pm    Post subject: Reply with quote
Pretty simple device. Unless there is a wiring fault you may be seeing an actual fueling problem.
PostPosted: Sat May 13, 2017 11:12 pm    Post subject: Reply with quote
It's an AEM unit, and I do not have the recalibration issues with mine that are commonly reported with the Innovate stuff.
It is almost certainly a failed sensor due to the <ahem> event that you experienced.
canyonblaster
PostPosted: Wed Jun 14, 2017 3:54 am    Post subject: Reply with quote
Thx guys. We replaced the sensor. AFR gauge is same, wonky, all over the place. I am taking the car to better shop, one that has smoke and can fix it.
924-76
PostPosted: Sat Jun 17, 2017 9:51 pm    Post subject: Reply with quote
... you may be seeing an actual fueling problem.
Have you check you fuel pressure? Could be a faulty WUR.
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
