Posted: Sat Jun 03, 2017 5:25 pm Post subject: |
What is the weight of just the alu pressure plate ? _________________ 937 trackday car
Lau Christophersen
Joined: 17 May 2013 Posts: 108 Location: Denmark/Copenhagen
Posted: Sat Jun 03, 2017 6:12 pm Post subject: |
Dutch924-racer wrote: | What is the weight of just the alu pressure plate ? |
I will look later, I dont have the numbers at the moment _________________ 76 924 (PARTS)
77 924 (PARTS)
77 924 converted to 924S
77 928
79 931
79 931(PARTS).
79 931 Carrera GT look (PARTS).
79 931 with VEMS and opgrades
81 928S +30 cm widebody kit
82 924 (SOLD)
83 928S
86 944
86 944 (S2(SOLD))
89 944 S2 (SOLD) |
Posted: Sun Jun 04, 2017 3:06 am Post subject: |
Lau Christophersen wrote: | Dutch924-racer wrote: | What is the weight of just the alu pressure plate ? |
I will look later, I dont have the numbers at the moment |
4.3kg _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Sun Jun 04, 2017 3:51 am Post subject: |
This is the B1 version, I thought those where lighter ? _________________ 937 trackday car
Posted: Sun Jun 04, 2017 7:48 am Post subject: |
From here:http://www.924board.org/viewtopic.php?t=20855&postdays=0&postorder=asc&highlight=911+pressure+plate&start=15
Sachs #3032.015.399-b2
Alloy casing / alloy friction surface
*requires modified 931 ring gear, or 911 ring gear
Weighs 6.5 lbs. with TO bearing
Sachs #3032.015.399
Alloy casing / iron friction surface
Works with stock 931 ring gear
Weighs 9lbs. with TO bearing
Sachs #3032.055.099
Iron casing / iron friction surface
Stock 931 pressure plate
Weighs 14lbs with TO bearing _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
Lau Christophersen
Posted: Mon Jun 05, 2017 8:55 am Post subject: |
Here are some weight numbers of the clutch parts:
Fidanza aluminium flywheel(mod. to S1 PP and with ring gear for 924 N/A starter) 3,45kg
Original steel flywheel 7,80kg
Aluminium pressure plate(Sachs #3032.015.399-b1)eksl. TO bearing 4,36kg
Original pressure plate(S1 and incl. ring gear) 8,20kg
Ring gear(S1) 1,76kg
TO bearing 0,39kg
Friction plate with carbon 1,35kg
Complete original clutch: 17,74 kg
My modified clutch: 9,39 kg
Difference: - 8,35 kg _________________ 76 924 (PARTS)
77 924 (PARTS)
77 928
79 931
79 931(PARTS).
82 924 (SOLD)
83 928S
86 944
86 944 (S2(SOLD))
89 944 S2 (SOLD) |
Posted: Mon Jun 05, 2017 1:00 pm Post subject: |
Even with late offset suspension in the rear, it's still gonna need about 2" additional spacer to fill up those arches. #DemHips
Removed the standard 82 016 Audi gearbox to make way for a freshly rebuilt 951S unit with Wavetrac LSD and cooler loop.
SPAX coilovers with T-bar delete. Those springs will be replaced with 500# rears and 350# fronts.
_________________ erstwhile owner of just about every 924 variant ever made |
Posted: Mon Jun 05, 2017 8:55 pm Post subject: |
Could not resist and installed the GT seats in the 931(red one isn't insured at the moment)
My god those seats transform the driving experience :shock:
Had a fun drive on a gravel road
enjoyed the local lake/beach again
Had coffee in the city
And drove into the sunset
_________________ https://www.the924.com |
Posted: Sun Jul 02, 2017 10:10 pm Post subject: |
you guys dead or what?
Designed and printed a set of seatbelt bezels for the red car and generally enjoying the sun.
hdrider19
Joined: 03 May 2016 Posts: 193 Location: Catawissa Missouri(40 mi sw of St Louis)
Posted: Wed Jul 12, 2017 1:08 pm Post subject: |
Not dead just working hard to get things done Morghen.
Body and paint work done on my euro bumper. I still need to go thru all the lights to get them in good shape. I love the look of my car from the front now. I get my paint from the local O'reilly autoparts store. They mix to my color code and put it in spray cans for about $20.00 per can. The color match was pretty good.
_________________ 87 924S |
Posted: Wed Jul 12, 2017 4:19 pm Post subject: |
looks nice, can you get some clear lenses for those wing round markers? _________________ https://www.the924.com |
Posted: Tue Jul 25, 2017 5:23 am Post subject: |
This past weekend i cleaned the GTS wannabe and had a drive...i hadnt driven it for about 3 months or more. Forgot how powerful it is and kept going sideways
Also forgot how good looking this thing is.
Kenodog
Posted: Tue Jul 25, 2017 6:28 am Post subject: |
Oh ! Look who got the roof on his garage !
Lee _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Posted: Fri Aug 04, 2017 5:17 pm Post subject: |
Enjoying the ratty 931.
Posted: Sun Aug 06, 2017 7:51 pm Post subject: |
I bought a VAGCOM scanner and scanned the 1.8t. The cam sensor had one of the prongs making a bad connection. It runs very nicely now but the N75 valve is bad which means no boost untul I get a new one. I would post pics and videos but photo bucket. |
