PieszczoH
Joined: 03 Dec 2009 Posts: 59 Location: Warsaw Poland
Posted: Fri May 05, 2017 7:40 pm Post subject: location of 924cgt air intake, side blinkers and rear panel? |
Hi every one...
I thought I will ask for every one that tries to build 924CGT replica
Does any one know dimensions for:
locating the air intake in the hood?
locating the 928 blinker in the front wings?
locating the rear arch from the body line? |
v8carreragts
Posted: Mon May 15, 2017 12:09 pm Post subject: |
I can get you the dimensions for the hood scoop. The rear arches depend on which ones you have. The CGT and CGTS are slightly different. The CGTS mount a little higher than the CGT. _________________ 84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze |
Posted: Mon May 15, 2017 6:47 pm Post subject: |
The GTS ones are taller, they all mount vertically to match the reflect line of the car, and horizontally there is a feature in the back where it meets the bumper that has to sit at the nominal gap with the bumper. That positions the rear arches.
Front blinkers is more difficult...you can buy my original CGT front wings and be done with it  _________________ red 924 and not red 924 |
PieszczoH
Posted: Tue May 16, 2017 9:29 am Post subject: |
Guys I know that CGTS and CGT rear arches are different. I know that it is like 1cm vs 3cm from the body line... but if someone has a CGT or knowledge it would be the best to speak.
What I think about front blinkers is that they start just like in the 944 just after the body line pressed in the front wing, but due to the longer blinker they ends more to the front.
as for the intake.... info would be apreciated.
Morghen as for the rear arches I don't know if i understand You right.
What feature are You thinking of?
What I belive it has to make straight line arch and bumper from profile view
There was an Ideola CGTs picture showing that. |
PieszczoH
Posted: Thu May 18, 2017 7:11 am Post subject: |
Ok so rear arches depends on the reproduction of the arches that You are able to buy. |
Joined: 01 Oct 2004 Posts: 15515 Location: Woodstock IL
Posted: Thu May 18, 2017 11:31 am Post subject: |
CGT pix here and here.
I will try to get measurements this weekend. _________________ 15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini |
v8carreragts
Posted: Sun May 21, 2017 7:18 am Post subject: |
The right side of the scoop is 12" from the edge of the hood at the closest part and the front is 10 1/2" from the front of the hood measured at the center of the scoop. _________________ 84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Chevy Cruze |
