Posted: Mon May 15, 2017 4:15 am Post subject: Need help with 931 engine problems |
I have a/ some problems with the 931 series 2
When cold: running rough at idle/ low rpm
When warm:
Running nicely, great power
But running lean at cruise(AFR 17-20) and under boost (+/- 14)
Vacuum reading is 13/14 – the vacuum gauge says problem with timing
I checked the timing with a stoboscoop and I can see the ‘dot’ on the flywheel which seems to be good.
The enige is fully rebuild.
Modifications:
951 turbo s and intercooler
Stage 1 camshaft
Forge boost controller
Forge recirculation valve
937 DITC
What direction should I be looking for ? _________________ 937 trackday car
Posted: Mon May 15, 2017 4:25 am Post subject: |
Have you perform a smoke test for vacuum leak?
What is your AFR at idle?
Vacuum gauge should read around 17 at idle. _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
gegge
Posted: Mon May 15, 2017 4:39 am Post subject: |
Check CIS pressures, guessing the WUR. _________________ Carl Fredrik Torkildsen
Posted: Mon May 15, 2017 4:46 am Post subject: |
WUR
Check the CIS pressures.
Check if injectors are working right.
Check if fuel pump is getting 20 Amps. _________________ https://www.the924.com |
Posted: Mon May 15, 2017 4:47 am Post subject: |
AFR at idle is 14.5-15.
I haven't checked the fuel pressure yet. Will do that next week.
Injectors are new
What do you mean with check the fuel pump is getting 20amp ? _________________ 937 trackday car
Posted: Mon May 15, 2017 5:21 am Post subject: |
just pulled out the spark plugs, the all look black, so they don't look like it is runnign lean _________________ 937 trackday car
Posted: Mon May 15, 2017 5:47 am Post subject: |
Can you swap out the AFR sensor and gauge to rule out readout error? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon May 15, 2017 5:58 am Post subject: |
recalibrate your wideband sensor and gauge. _________________ https://www.the924.com |
Posted: Mon Jun 05, 2017 5:49 am Post subject: |
Checked the fuel pressure today with a running engine:
Pump pressure: 6,2 bar (should be between 5,8-6,5) ok
Cold pressure: 1,5 bar (should be between 2,4- 2,8 ) not ok
Warm pressure: 2.0 bar (should be between 3,45-3,85) not ok
Does this means my WUR has not died ?? I haven't checked if it gets 12v yet.
Posted: Sat Jul 01, 2017 1:28 am Post subject: |
problem solved, the wur was bad, replaced it and all pressures are good now.
AFR is also good at cruise now _________________ 937 trackday car
