Recirculation valve/ BOV which way ?
PostPosted: Fri May 12, 2017 5:06 am    Post subject: Recirculation valve/ BOV which way ? Reply with quote
As I am running a 944 turbo I use an axternal recirculation valve/ BOV (from Forge).
On the internet I see two differant way's to mount it (boost in/out), is this the correct way or doesn't it matter ?
PostPosted: Sat May 13, 2017 1:34 am    Post subject: Reply with quote
Don't need a dump valve. Run a closed system
PostPosted: Sat May 13, 2017 3:46 pm    Post subject: Reply with quote
The original turbo also has a built in recirculation valve/ BOV. Because the 944 turbo doesn't I use the Forge external one.
PostPosted: Sat May 13, 2017 6:51 pm    Post subject: Reply with quote
Pressure in from below. Pressure out at the side. Vacuum/boost signal above. Forge say do not reverse the flow. Is that a pic of your forge BOV ?
Try it with and without BOV. They aren't always needed.
PostPosted: Sat May 13, 2017 7:12 pm    Post subject: Reply with quote
ok, thanks so the pictue is telling it wrong
The picture above is not my recirculation valve but it looks simular, this is the Forge I use:
