How to fix front valance?
mikeycrum14
PostPosted: Tue May 09, 2017 2:01 am    Post subject: How to fix front valance? Reply with quote
What is the best way to approach this repair?
replacement is not an option unless its dirt cheap.
how do i pull the valance?
sand and prime and repaint?
http://i682.photobucket.com/albums/vv182/mikeycrum14/IMG952017011995210921_zpsrzz7my2r.jpg
this is what it looks like right now...
1981 924 - Alpine White
First car!
Fresh tune up, stage 3 racing clutch, stock otherwise, 5 speed trans. - SOLD
edredas
PostPosted: Thu May 11, 2017 11:24 am    Post subject: Reply with quote
I've repaired a few of these. There are a some 10mm bolts and screws holding it on... so not terribly hard to remove. Once it's off you can straighten it out and use fiberglass filler to smooth it out.
The panel was textured from the factory and SEM heavy texture chip guard is a great, if not perfect match. Then you can primer and paint over top!
I hope that helps!
'87 924S -Red, 300hp 951 swap
'87 924S -Red, New Project
'87 924S -White, Automatic
'88 924S -Red, Daily Driver, Bone stock
'93 Mx6 -White, Megan Racing suspension
mikeycrum14
PostPosted: Fri May 12, 2017 12:07 am    Post subject: Reply with quote
Cool. will post progress once i get onto doing the repair.
First car!
