BMA Body Kit ?
Goto page Previous  1, 2
Ozzie
PostPosted: Fri May 05, 2017 7:28 am    Post subject: Reply with quote
There was a glass sunroof for these cars- worth more than the car sometimes
Its AUTO and its BLACK
Montego Black on black/red
MrNodoughchar
PostPosted: Fri May 05, 2017 7:36 am    Post subject: Reply with quote
Are you talking about the Saratoga sunroof ? This one is fitted with one that I've never seen before. It doesn't look like a Saratoga as it's slightly smaller than the factory size as far as I can tell and has a different shape.
Ozzie
PostPosted: Sat May 06, 2017 6:40 am    Post subject: Reply with quote
thats the one, Saratoga
MrNodoughchar
PostPosted: Mon May 08, 2017 3:09 am    Post subject: Reply with quote
The 924 that I have my eyes on has either this exact sunroof or one that is incredibly similar. I don't know if it opens the same way because I've never seen it open.
http://www.2040-cars.com/Porsche/924/1977-porsche-924-base-coupe-2-door-2-0l-861245/
Harm
PostPosted: Mon May 08, 2017 3:45 am    Post subject: Re: BMA Body Kit ? Reply with quote
FYI that^ is a so called aftermarket sunroof and holds no value.
Even more so it is likely to be leaking, sitting for ~17 years outside, and so the almost 40 year old interior is probably ruined and in need of a replacement?
That will ruin your summer budget.
MrNodoughchar
PostPosted: Mon May 08, 2017 3:56 am    Post subject: Re: BMA Body Kit ? Reply with quote
Yes. I understand that it's aftermarket. I never did mistake it for a Saratoga because it's much smaller. I'll have to see if the interior has been ruined by leaks when I go and meet the owner. If it has been leaking it'll make the project more fun and I could probably pick the car up for damn cheap However, if it's beyond my means then I'll have to unfortunately leave the car to sit for many years to come.
MrNodoughchar
PostPosted: Mon May 08, 2017 3:56 am    Post subject: Reply with quote
Just to clarify, the 924 I'm after is a LHD.
Harm
PostPosted: Mon May 08, 2017 4:01 am    Post subject: Re: BMA Body Kit ? Reply with quote
Something you could do already is read into the CIS topic and K-Jetronic basics, or you'll get it no where
Cheers.
MrNodoughchar
PostPosted: Mon May 08, 2017 4:04 am    Post subject: Re: BMA Body Kit ? Reply with quote
Cheers.
I've been doing some reading but it'll be extensive after my exams finish.They begin in 2 weeks.
Page 2 of 2
