vwfye
Posted: Tue Mar 28, 2017 2:18 pm Post subject: |
Thanks for the answer!
BTW, after a few years of not being on the road due to bad fuel pressure regulator and a bad pump. Now, it is alive.... sort of. Tell me if you think these might be causing an issue:
Posted: Thu Mar 30, 2017 5:25 am Post subject: |
Obviously that cylinder is running very rich. This will kill gas mileage, reduce power, and dilute the oil with gasoline.
Time to check injector flow rates and check the system and control pressures. _________________ White 87 924S "Ghost"
vwfye
Posted: Fri Mar 31, 2017 1:44 pm Post subject: |
they were all that way, but they were also that way prior to dealing with fuel pressure issues. |
vwfye
Posted: Wed Apr 12, 2017 2:05 pm Post subject: |
new injectors finally arrived. now to install and reset fuel pressure. |
vwfye
vwfye
Posted: Mon Apr 17, 2017 5:04 pm Post subject: |
morghen wrote: | sounds nice |
i'm sure hoping it drives nice as well. |
vwfye
Posted: Fri Apr 21, 2017 1:29 pm Post subject: |
40 mile drive today brought some success and a few issues to light.
Cold idle is a bit rough while full warm up idle is at 2000rpm.
Window on right side stopped going up/down today.
Power mirrors aren't working, might be a fuse.
Water from below the battery is probably the right front sunroof issue.
Didn't realize the rear seats didn't have seatbelts in 1980. Weird |
vwfye
Posted: Sat Apr 22, 2017 10:54 am Post subject: |
did lots of little work on the car today... then out for another spirited, back road, mountain pass run. Back toward home I stopped for fuel. Didn't want to restart easily. Now worries, almost home. Then, the last intersection to traverse it stalls and won't start in the turn lane. Shoving it out of the intersection without help and a big 4x4 snorting on my bumper the car gets away from me on a down slope and...
[img]https://scontent-sea1-1.xx.fbcdn.net/v/t1.0-9/18034249_10212620552289878_3166996932390000440_n.jpg?oh=666a6a50f36c6099cd2106a1f75ec341&oe=599218E6[/img]
... a 4" thick pole and a curb help it come to a stop. Valance is also damaged.
The reason it stalled was the failure of a factory crimp clamp. Oh... about 4 gallons of fuel went on the ground.
Posted: Sat Apr 22, 2017 4:01 pm Post subject: |
Sorry to see this...beginners bad luck I guess. Go fix it and drive it. _________________ https://www.the924.com |
vwfye
Posted: Thu Apr 27, 2017 2:51 pm Post subject: |
Driving the car, now that the fuel supply is working, is great! I need to sort out why it is so cold blooded for the 1st 2 minutes. It goes pig rich when you try and give it gas to pull out until it warms. After that, it runs awesome! |
Posted: Fri Apr 28, 2017 12:53 pm Post subject: |
Where in Oregon are you? _________________ Toofah King Bad
vwfye
Posted: Fri Apr 28, 2017 12:59 pm Post subject: |
Sw. 120 from Cal on i-5. You? |
vwfye
Posted: Fri Apr 28, 2017 1:49 pm Post subject: |
Headlights are now adjusted. whew! But, it is obvious I need to upgrade to halogens. These old standard bulbs are dismal.
A question, how rare is the LA3V paint? Also, how do I read my VIN to see what color it wore originally? I don't know if this is the OG color.
Thanks! |
vwfye
Posted: Fri May 05, 2017 1:15 pm Post subject: |
Working on a/f ratios right now. Went from pig rich to a bit lean. Now working my way back to 14.7. |
