jvandyke
Joined: 30 Mar 2016 Posts: 212 Location: Hudsonville, MI
Posted: Thu Apr 20, 2017 6:03 am Post subject: |
still trying to get temp and fuel gauges happy, can't find the ground point up under the dash, we had erratic readings from both for a while, now nothing, really suspect the grounds, where is that grounding point? _________________ 87 924S project, '83 944 engine,
my son's first car. |
jvandyke
Posted: Fri Apr 21, 2017 12:03 pm Post subject: |
pulled gauge, disassembled, could tell right away that wasn't the problem, all was tight and clean, lost a gauge light in the battle
All the other idiot lights in that pod are fine so why the temp and fuel are inop is just weird, the temp gauge does "energize" with the key coming on, the needle snaps up to attention but never moves with engine operation, the fuel gauge is totally dead which is very strange since it worked badly, then I messed with the sender then it worked fine, then it went dead, could be two unrelated problems, like bad temp temp sender and bad fuel sender at the same time
later that night
pulled wire off sender on engine block, grounded it, needle maxed, then used on old potentiometer and needle followed my adjustments
I guess it's the sender.
Anyone want to trade for the '87 924s sender we bought a few months ago and won't fit our '83 944 block? _________________ 87 924S project, '83 944 engine,
hdrider19
Joined: 03 May 2016 Posts: 193 Location: Catawissa Missouri(40 mi sw of St Louis)
Posted: Mon Apr 24, 2017 1:59 am Post subject: |
Have you thought about drilling the hole in the block and tapping to correct thread for the 924S sensor? That is what I will do on mine I plan to have my wife hold a shop vac hose by the drill bit to keep chips out of the water jacket. _________________ 87 924S |
Posted: Mon Apr 24, 2017 2:39 am Post subject: |
Did you check the big ground cluster under the intake? _________________ Toofah King Bad
jvandyke
Posted: Mon Apr 24, 2017 7:47 am Post subject: |
Rasta Monsta wrote: | Did you check the big ground cluster under the intake? |
Where is this exactly? Could be a problem. We lost everything to an engine fire before we were really familiar with the car so it could easily be I missed something obvious. _________________ 87 924S project, '83 944 engine,
jvandyke
Posted: Mon Apr 24, 2017 7:51 am Post subject: |
hdrider19 wrote: | Have you thought about drilling the hole in the block and tapping to correct thread for the 924S sensor? That is what I will do on mine I plan to have my wife hold a shop vac hose by the drill bit to keep chips out of the water jacket. |
I did but I don't think it's a sender/gauge mismatch anymore. I think it's just a bad circuit--bad sender/bad ground. I ordered a new early 944 sender and with a new sender and more ground chasing we'll go from there. _________________ 87 924S project, '83 944 engine,
Posted: Mon Apr 24, 2017 8:24 am Post subject: |
jvandyke
Posted: Mon Apr 24, 2017 8:32 am Post subject: |
oh, yes, the main grounds by bell housing, got those clean on tight, thought maybe there were more, thanks though _________________ 87 924S project, '83 944 engine,
jvandyke
Posted: Wed Apr 26, 2017 9:13 am Post subject: |
new sender arrived, installed; all good, thanks for the input everyone, just to clarify, it seems the early 944 sensor (pre '85?) the "button style" works with the later 924s gauge, at least on test run around the block it read in the middle of the gauge where you'd think it would be.
What a lot of red herrings. _________________ 87 924S project, '83 944 engine,
